Question about Image 10.4Ql Treadmill Walking Belt
Looking for step by step instructions to replace treadbelt on Image 10.4QL
Belt rolls but tends to grab and jerk. I thought it was just my weight (275lb - ish), but it does this (increasingly so) even when my teenage daughter uses it. It's the same belt since purchase in 2002, guessing it's time to replace. I do have an extra belt from when I purchased the machine and I'm willing to just tear into it, but would prefer some direction.
    Top Expert:
  • Image Master
  • 12,223 Answers
See the video and proceed according. God bless you
Posted on Jan 23, 2013
Testimonial: "Thanks for responding. The video gave me a general idea, but infortunately the drive roller is not as easy to remove. I haven't been able to figure it out so far."
MACHINE STOPS AS WEIGHT IS LOADED
Assuming that the console stays on, it seem you have one of three problems
  1. Your front roller is faulty
  2. Your Treadbelt is loose
  3. Your drive belt is loose
You may also have a combination of two or more of the above issues.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Dec 23, 2014 | Life Fitness T3 Treadmill with Advanced...
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
While walking on my tredmill the belt jerks
Sometimes mine can "****" when my body weight on the front foot slightly slips the belt forward before I put full pressure on it and it slides back into normal walking. Don't know what your natural walking style is like, but this tends to happen when I am "heavy" on my heel with that forward step. Could also be that your belt needs lubricating (buy from sports stores).
Nov 27, 2010 | RTO Image 15.0R Treadmill Walking Belt
The treadmill seems to work fine at first then the belt kinda sticks. It like stops and goes. Electrical seems fine
It's possible that your treadbelt needs lubrication, or simply adjusting. Here is a tutorial on adjusting your treadbelt:
Here is one link to purchase a lube kit, there are probably many others online also:
Should you actually need to purchase a new treadbelt, I would try to identify which specific model of the Proform 530 you have from this list and then in the parts list for that treadmill scroll down to "Treadbelt"
Oct 14, 2010 | Proform 530 Treadmill Walking Belt
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
If I stand on the belt it stops moving
Unplug unit remove motor shroud so you can see the drive belt, plug in unit then start it you will be able to see whether the drive belt or running is actually causing the problem.If it is the running belt then turn both rear roller adjustment bolts clockwise in equal quarter turn increments until treadbelt stops slipping. NOTE: Be sure to run on treadbelt to ensure that the treadbelt does not slip while under load. Use 1/4" allen wrench
If the drive belt is slipping then to adjust the belt you must loosen the adjusting bolt on the motor frame then hold the motor by hand applied tension to belt then tight bolt you should be able to twist the drive belt no more then 45 degrees if you can repeat adjusting process.
Mar 13, 2010 | Proform 760 CrossTrainer Treadmill
Xp 590s belt is grabbing or jerking. I tried
probably a bad drive belt, they cost 20-30 bucks, possibly the front roller. You have to take the cover off and look to be sure.
Sep 25, 2009 | Proform XP 590S TREADMILL Drive Motor
Replacing vacume belt
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have no idea how to put the belt back on
Image 10.4Ql Treadmill Walking Belt Logo
56 people viewed this question
Top Image Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Image Exercise and Fitnes Expert? Answer questions, earn points and help others
