Question about EliteGroup ECS K8T800-A (1.0) AMD K8 SOCKET754 HT1600 DDR400 ATX RETAIL Motherboard
Memory problems i installed 1 gig of memory but it only reading 512
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    The maximum supported memory for this motherboard is 512 MB.
  • 29 Answers
If you are sure your motherboard can handle a 1 GB RAM stick, then the general answer is that the motherboard can not run High Density RAM stick as yours is possibly. You might need to exchange it for a stick of Low Density RAM.
According to some quick research, it says your motherboard can only read up to 2 GB TOTAL of RAM even if you have more installed.
Posted on Jan 27, 2009
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
How do I install more memory in a Gateway GT5464?
Please look into the below link for user guide manual to install Memory into your computer:
Refer to page no: 37: To Install or replace DIMM memory.
Here is the link:
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Regards,
Shami
Dec 03, 2010 | Gateway Computers & Internet
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
I just upgraded memory from 512 to 2 gigs, but the computer only shows 1 gig. why?
The other 1 gig is not properly installed oropushed in all the way
Oct 02, 2009 | Acer Computers & Internet
I have 2 512 ram cards i tried to install a 1 gig card it didn't work and now my computer only sees one of my 512's
you need to pair memory modules. you need to buy another gig of memory and have it paired
Jul 09, 2009 | Acer Aspire 7110-2069 Notebook
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
P35-611 Memory upgrade question
hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
this may just be a read problem and it needs to learn that you have a 2 gig mem
if not let me know and we can try another way for you ok
hope this helps ok
all the best
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
112 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
