Question about GE Adora DVM1850 Microwave Oven
GE adora DVM1950SR1SS operating manual - GE Adora DVM1850 Microwave Oven
Where is the fuse located on the GE Adora DVM1950SR1SS Microwave Oven
The fuse is located inside your Adora microwave oven.
Sep 02, 2014 | Microwave Ovens
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Either way, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
Ge Adora dryer model#DHDVH52EFOWW started making a screeching noise in the middle of a cycle and does it again if I restart it.
remove door and check horse shoe shaped plastic guides located at the top of the door that the drum rides on for wear....replace if worn
Jan 03, 2011 | GE Adora DVM1850 Microwave Oven
GE Adora Microwave 1850 stopped working everthing is dead. Power is ok to unit
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 21, 2010 | GE Adora DVM1850 Microwave Oven
Not heating
most likly it is the mag and the diode. it should be covered for ten years after you bought the unit so check into that. you will have to pay a ge authorize servicer to replace it though but parts should be covered and still cheaper than a new microwave
Jun 02, 2010 | GE Adora DVM1850 Microwave Oven
My GE Adora Spacemaker XL 1800 is no longer heating the food. What do I need to do to replace the microwave emitting bulb?
may be , the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. it need to be replaced .
Jan 11, 2010 | GE Microwave Ovens
Microwave, adora, stopped heating
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Mar 14, 2009 | GE Adora DVM1850 Microwave Oven
GE XL 1800 adora Microwaves shuts down
It sounds like the magnetron is overheating and opening the thermostat.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Dec 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Adora DVM1850 Microwave Oven Logo
131 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
