Question about Samsung LN40A550 LCD TV
New Samsung LN40A550 LCD TV: picture is not crisp.
Assuming the cable feed is not the problem, what picture settings do you think would improve the definition ? Does this unit have any quirks one has to work around to improve picture quality ?
  • 98 Answers
If you play with blu-Ray with HDMI, you will see the amazing picture quality.
I guaranty.
Posted on Feb 06, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung LN40A550 color problem
Check all your input & input cables, then try a DVD player hook-up with known good cabling. I still have color issue may need MAIN PCB. part# BN94-01723Q $ 81.95
http://www.shopjimmy.com/catalogsearch/result/?q=+BN94-01723Q
$81.95
Mar 04, 2014 | Samsung LN40A550 LCD TV
$81.95
Trying get the best picture for ps3 gaming
Plug your ps3 to the tv with a HDMI cable. go to Setting > Display setup on your ps3> Look for output/connection type. Select HDMI cable> Select the highest resolution your tv has 1080p or 720p. There you get the best picture for playing your ps3 gaming.
Mar 09, 2011 | Samsung LN40A550 LCD TV
I have a brand new samsung 46' lcd tv and the picture is not crisp it is very fuzzy?? What do I do?
More than likely your set is fine and you need to provide it with a HD signal. Contact your cable or satellite provider for an upgrade
Jun 02, 2010 | Samsung LN32A550 32 in. LCD TV
Can somebody pls. help...our tv Samsung LN40A550 LCD would not turn on...the red light (power) keeps blinking & the blue bar is turned on too as soon as you plug in the tv but the screen won't turn...
This is a very common problem. The power supply board has failed and needs to be replaced. You can call 1-800-samsung to find out if this problem will be covered under a warranty and the nearest service center. I replaced at least 150 power supplies last year.
Mar 05, 2010 | Samsung LN40A550 LCD TV
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
I bought this on clearance. I hooked it up and
This is probably the LCD Controller (T-CON) board connections. This is a small board with 2 flat cables connected to it which run to the LCD screen. The connections with the flat ribbons needs to be reseated. The heat makes the connections misaligned. This board is usually covered by a metal shield.
When you reseat the connections, run the set for 15 minutes to see if it works before replacing the back cover. You may have to reseat it again.
Remember, handle electronics boards by the edges, no static electricity, and do not touch the connection contacts.
At worst you would need a new board. (Shopjimmy.com has it for ~$90.00usd)
May 09, 2009 | Samsung LN40A550 LCD TV
Samsung LN40A550 LCD TV Logo
294 people viewed this question
Henry  Thomas
Henry Thomas
