Question about OKI B2520 All-In-One Laser Printer
Oki mb290 "printer error fuser - OKI B2520 All-In-One Laser Printer
SOURCE: I have an OKI B2520
This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
Posted on Dec 30, 2009
copiersplusw
  • 136 Answers
SOURCE: fatal error 928 Oki C5500
Open the Unit Up, the Button on the Side opens the Printer. In the rear of the Printer you will notice the Element in the rear of the Printer.
It is usually hot. Well there is latches
as an Authorized Okidata Service Provider I believe these "TABS" should be the color of BLUE. release the tabs and the entire fuser come out just grab the handle that usually comes equipped with the fuser , it is usuallyon top just grap ir and lift it out. Install the New One and your Done.
Posted on Sep 13, 2009
SOURCE: OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX
Posted on Feb 12, 2010
SOURCE: Error 020 on OKI B4350 printer
After pushing the on button, RAM CHK- initializing-- on-line - auto, and then, over and over and over again. It just goes in a circle.Pardon my english. Denmark is calling :-)
Posted on Feb 15, 2010
  • 97 Answers
SOURCE: Hello , my oki b6200 display error replace fuser
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Posted on Mar 29, 2010
Error fatal 928 how to fixe it
Error 928: Fuser Motor Lock Error An error was detected with Fuser Motor rotation by overload. If rebooting the machine does not improve the symptom, you need to check the Fuser Unit.
Sep 09, 2014 | Oki Data Americas, Inc. OKI C 711n -...
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
Oki printer MC860 is displaying fatal error 928. What does this mean
This is a fuser motor lock error. Check that the fuser is installed normally. You may need to replace the fuser unit or the fuser
motor.
Dec 03, 2013 | Oki Electric Industry MC860 AllInOne Led...
OKI MC860 ERROR 928
This is a fuser motor lock error. After cooling check that the fuser is installed normally. You may need to replace the fuser unit and possibly the fuser motor.
Oct 11, 2013 | Oki Electric Industry MC860 AllInOne Led...
Service call 984: fatal error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Mar 20, 2013 | Oki Brand Oki C610n Laser Printer...
ERROR 173 050914
Low fuser Temperature Error - Replace fuser or thermistor in the fuser - per Oki Svc Mnl
Fuser error. Replace fuser or if no-go, Main board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 27, 2011 | OKI B4600 Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
OKI B2520 All-In-One Laser Printer Logo
979 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
