Question about Samson Graphite 49 - USB/MIDI Keyboard Controller
My brand new Samson Graphite MIDI Controler Keyboard hanging whenever i will save an edited data. i have to unplug the cable power or the USB cable to swicth it off and open again for me to use it. th
It hangs whenever i go to settings and i edited something, i cannot save it normal way, whenever i save it when i go back to the main menu it hangs there that i have to unplug the usb cable and open it again for me to use again. the store change the unit again so i have a new the same unit again however when i start to use it at home it happens again, hangs it there, the same problem... is it a factory program problem of the samson graphite 49. thanks for whatever answer you will have guys..
I have the same same problem with my unit, i really need help !!! The problem is still there , even if you do a firmware upgrade . i also returned the unit to the retail store and have a new one with the same problem, the software editor doesnt work on windows 7 but in windows xp with 1.92 version, please check my video
http://youtu.be/DKn5ArIxl4M
Posted on Apr 30, 2013
One key occasionally not sounding
Defective keyboard. Not much you can do but replace!
May 11, 2015 | Samson Carbon 49 USB/MIDI Keyboard...
Corrupt data
PX 410r uses IDES 4.0 downloadable from
http://www.casio-europe.com/euro/emi/specials/ides/downloads/
and not another version.
I suggest you uninstall the Casio USB driver from Control Panel'system'device manager then Reboot the PC without the USB cable.
Download latest USB driver from :-
http://support.casio.com/en/support/download.php?cid=008&pid=20
64 or 32 bits versions are both available.
Load driver first. Plug in the usb cable only when software tells you to do so.
Uninstall Data manager if wrong version.
Install IDES 4.0
Mar 08, 2014 | Casio Music
My Samson Carbon 49 keyboard controller. Under Device Manager/Sound, video and game controllers - DTMB BDA TV USB Properties General, This device cannot start. (Code 10).
1. Go to devices and printers.
2. Double click SAMSON Carbon49 to open
3. Hardware > properties > General > Change settings > Driver > Uninstall.
4. Turn off the device and turn it back on.
5. Hardware > properties > General > Change settings > Driver > Roll back driver.
Should work now
Jan 16, 2014 | Samson Carbon 49 USB/MIDI Keyboard...
Lcd blank
From the information I have, the unit will need to be repaired. No quick fix to repair for a blank display problem. Either the cable to the LCD screen became detached or the display is bad. The cable will be internal.
Nov 29, 2013 | Samson Graphite-49 Keyboard Usb Midi...
Midi-USB cable providing wrong data (notes) to pc? I have a Yamaha YPT 220 / PSR E223 keyboard, and a "generic midi usb" cable wich is actually an Agptek midi usb like cable, (Treble cleff logo ;) ). My...
Make sure that you have the correct midi mapping for your Yamaha. There should have been a software program, called a mid map editor (MME), that came with your keyboard. If you are unfamiliar with this, it is used for changing the values that are sent through the midi cable into your computer (for example, you can change the C0 to be C#0, or any other value, including a numeric value instead of a tonal value). If you bought it used there may have been values changed on midi-trigger presets, which would cause this. If you do have the program, use it to at least investigate that all of the values are in the right places. Often times when someone who is unfamiliar with an MME installs it they open it to see what it is. They change things (not realizing they have done that) and then can't figure out why there is a problem.
Also, make sure your midi cable has the same connections as your keyboard. Some brands make very slight variations to avoid patent issues that may make some cables and instruments incompatible. I have two cables that work fine with certain midi controllers, but when switched they both fail. It's good to make sure the plug ports are clean of dust/dirt, too.
If you are familiar with these problems and they are not yours, you may need to get a different cable. Try to borrow one from a friend to see if the cable is the problem before you buy one. If that still doesn't fix it you may have an internal software or hardware issue. Good luck! I hope I could help.
Aug 27, 2013 | Yamaha Ypt-220 61 Key Personal Keyboard...
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
Apr 03, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
Hey. Im having a problem with my samson g track when mixing down midi and audio. The midi comes out really quiet even though its on full volume. It doesn't mixdown correctly. I'm also finding it impossible...
MIDI isn't audio, think of it as a sheet of music. It still needs to be played to be heard. Not sure of your recording setup but the midi performance that you have needs to trigger a keyboard or drum machine or VST instrument of some sort.
Apr 01, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
I use the samson C01U usb microphone on my macbook pro for almost 4 years. Now I recently updated to mac os 10.6.6 (latest update) and Samson soft pre won't start up anymore. I can't configure the mic...
1. Try reinstalling the softpre software.
2. Read through their FAQ at: http://samsontech.com/products/productFAQs.cfm?prodID=1810&brandID=2
3. Contact samson directly at audio@samsontech.com with your problem.
Mar 03, 2011 | Samson C01U - USB Studio Condenser...
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Samson Graphite 49 - USB/MIDI Keyboard Controller Logo
176 people viewed this question
Top Samson Video Cameras Experts
Are you a Samson Video Camera Expert? Answer questions, earn points and help others
