Question about Konica Minolta DiMAGE Z2 Digital Camera
Battery Cover repalcement
Help! I have to replace the battery compartment door. I have purchased the new part but I cannot see how to fit it; all the parts seem to interlink. Very grateful for any advice or help on this. Thank you.
  • Anonymous Mar 20, 2008
    I've got the same problem with my DiMage Z1. I've got the replacement door but I am unable to find directions on how to install the replacement.
    Don duckgs31@comcast.net
  • 39 Answers
Where did you get the battery door replacement? If i get a replacement for mine i will update with a step by step walk through. with any pics i can.
Posted on Jun 06, 2008
I Know i can fix it. I've fixed many cameras before. if i can find a replacement door for mine i will post the pics and walk through. where did you get your doors?
    Sergeant:
    Champion:
  • 326 Answers
Hello, this task is not so simple. If you are shure in your technical background please leave me your email. I will try to send some tips on this matter. Best regards, Arpi
Posted on Jul 20, 2007
Bull Safe with two doors and 3 door front load. Battery compartment on both doors are broken. Currently held by tape. Is it possible to order a replacement cover to hold the batteries securely?
You should be able to purchase replacement parts..Check your manufacturers Website /support page ..and check eBay also . Good luck
Nov 16, 2016 | Cameras
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Mark of Fitness, wrist blood pressure monitor MF-78. Purchase date: a few years ago, I really don't remmber the date, From QVC. The screen is flashing the picture of the battery. This happens when i try to...
The picture looks very much like the Walgreens brand, which is manufactured by HoMedics. If that is the case, you can access the batteries as follows:
1. The battery cover is located along the bottom side of the monitor. Remove the battery cover by pressing down and pulling away from the monitor.
2. Remove the old batteries and take note of whether they are corroded or not. Install the new batteries according to the polarity indications inside the battery compartment. It will require 2 - AAA Alkaline Batteries..
3. Replace the cover by inserting it back into place.
Jan 25, 2011 | Mark Of Fitness MF 81 Wrist Blood Pressure...
I want to replace the cr2 battery.Where is the battery compartment for the Intermatic model ST01 self adjusting wall switch timer?
The battery compartment is located behind the pull-down door
Pry open the door with small screwdriver of fingernail file
http://waterheatertimer.org/ST01C-program.html#battery
If the battery goes dead on the Intermatic ST01C or EJ500, the screen will not display.
When replacing battery, wipe clean all the terminal points for battery and battery carriage
If the new battery does not restore the screen, then the timers needs replacement.
http://www.aplussupply.com/intermatic/timer.htm
Nov 03, 2010 | Electrical Supplies
I dropped my Sony DSC-W1/W12 camera. The battery door broke and will no longer close. The camera works fine with a little duct tape. Do they make a new battery cover to replace? Thank you all Marcia
Yes, you can get new battery holder that comes with cover, part number is as follows:
175648311.... HOLDER, BATTERY (WITH TERMINAL Silver)
DSC-W1 Camera will take apart to replace battery compartment.
Hope these info will help you.
Thanks.
Sep 27, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
Battery Door
remove two small phillips head screws next to battery compartment,,this will allow you to raise the camera case enough to insert the tabs from the new battery door cover,replace the screws,,,i just replaced mine not to difficult
Jul 15, 2008 | Kodak EasyShare CX4200 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
How to replace CF card slot cover?
The door kind of sits in a channel on the case. It should fit with the rod and spring that holds the door closed/in place. You need to remove the old door, and maybe the back part of the camera (there are screws inside the battery compartment, dont' forget them!).
If you can't fix it, leave a note with an email address and maybe my company can fix it for you.
Nov 12, 2007 | Canon PowerShot A80 Digital Camera
Battery compartment door
Only by examining the camera your self will you find out If you managed to purchase a part- perhaps an installation diagram is available from the same source.
Jul 31, 2007 | Kodak EasyShare DX4530 Digital Camera
Konica Minolta DiMAGE Z2 Digital Camera Logo
478 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
