How to scan for channels on a panasonic th-l32xm5a
Scanning channels
dave1645
  • 834 Answers
SOURCE: No Channels found after scan for new channels
was it working before ?
Are you on cable ? run your scan in cable mode
Are you on an Antenna run your scan in air mode
Posted on Dec 04, 2009
jerryg50
  • 1667 Answers
SOURCE: scan
Check to see if there is a feature in the user menus that allow to turn off the digital tuner section.
Also, check to see if your cable company is still feeding the digital channels to you.
It is best to consult the user manual to see how to set up the features of your set.
Jerry G.
Posted on Apr 17, 2008
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
SOURCE: Trying to scan channels into my vizio, but no
I called my satellite provider. Problem solved!
Posted on Jul 07, 2009
SOURCE: Incomplete Auto Scan of the channels
I ran the Auto Scan. Before the scan reached 91%, I pressed the Menu button on my remote and all of the channels that it found locked in.
Posted on Jan 08, 2010
I have a Panasonic 50" plasma tv (TH-42PX80U). I was told it has a built-in antenna but it does not pick up any channels after scan. What's the problem?
I have, if I'm not mistaking, the same model TV, and it doesn't have an internal antenna. If it have a coaxial input, there is no internal antenna.
Feb 07, 2015 | Panasonic Televison & Video
How to unlock Panasonic th-37lru50?
insert service line back of tv and re set OS with new re boot .
Sep 03, 2014 | Panasonic TH-37LRU5 37" Full HD LCD...
Panasonic th-c42hd 18 stopped receiving middle-numbered channels from my outdoor antenna. Auto Scan feature (& manual scan) only picks up a couple low- & hi-numbered channels. Is it possibly the...
Tuner is possible but check set is in air and not cable band---I would connected a dvd to see rear inputs ok---there may be a way to route the antenna signal to one of those and bypass the tuner(any box with its own tuner can be used.)
Nov 06, 2012 | Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
Th-p42g10a
If it has a digital tuner it should have a setting for auto program for that or the digital tuner may have a defect.
Jun 17, 2012 | Panasonic Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
AFTER USING THE AUTO PROGRAM CHANNEL OPTION I NOW HAVE ONLY CHANNEL 1 - HOW DO I FIX THIS - IS THERE A RESET BUTTON
Just unplug the TV for 10 min. Plug it back in and scan again. If you need further help, post a comment and I can help you further.
Jan 11, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
