Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Insufficient heat I have a Maytag LSG7806AAE and it takes forever (>1hr) to dry the smallest load. There is heat, but perhaps just not enough?!?
  • jlstebs Jan 27, 2009
    I should have mentioned that the venting has been checked out and it is fine.
    Thanks!
  • 65 Answers
I would start by checking the venting for obstructions. disconect the hose and try a load. dont leave the hose off for too many loads as the lint and moisture will go into the room.
Posted on Jan 27, 2009
  • Travis Gray Jan 27, 2009
    I have seen on some gas appliances where the ignitor may light up but does not pull enough amperage to open the gas valve. not sure what the amperage should be on that model, it should be in the service sheets. you will need an amp clamp type meter to read it.
Takes forever to dry even the smallest load , its has hot air coming out the exhaust and the clothes are warm .
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag LSG7806AAE that is 8 years old but never
These can last up to 15-20 years if you take care of them.
Apr 28, 2010 | Dryers
Dryer takes forever to dry clothes
Check out this tip... it will help you to find out what is making it take so long..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Maytag PYE2300AY Electric Dryer
Dryer gas heat not staing lit
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Dec 30, 2009 | Maytag LSE7806A Top Load Stacked...
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
My Neptune mde 9700 dryer heats inconsistently. more times than not it take forever to dry a load nomatter what the size
you have either a thermistor at fault of the heating element isnt operating properly
Aug 21, 2009 | Maytag Dryers
My Maytag model lsg7806aae takes too long to dry the clothes
check for restriction in vent duct. if there is good heat but takes to long to dry then there is restricted air flow through unit.
Jun 24, 2009 | Dryers
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
152 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
