Question about HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan
Cannot print 7x5 photo on hp 5510 as half picture missing
I can print a 4x6 ok, half picture missing when I print 7x5. It's fine on screen when I change setting
ctf1800
  • 4402 Answers
SOURCE: Printing photos from iPhoto to HP printer
go here
Posted on Feb 11, 2008
tecnomage201
  • 221 Answers
SOURCE: I have an HP officejet 5510. I want to print in black only/
Go into the printer options and set it for grayscale only.
Posted on Jul 28, 2009
SOURCE: HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Posted on Oct 13, 2009
SOURCE: Want to print 2 wallet size on 4x6 photo paper
under print options it will pop up a menu saying to "only show options compatible with my computer...." unclick that and it will allow you to select letter size paper again
Posted on Nov 20, 2009
SOURCE: I cannot get my HP
Just got a HP Photosmart Plus B210 and have the same problem!!
Prints fine from main tray but won't pick up from photo tray!
Any solutions yet?
Posted on Nov 19, 2010
Trying to print a 4x6 photo on HP photostock. First one printed fine. The second time it jammed. After fixing the jam, the pictures print up so high that the top half is cut off.
I have had a few HP printers that seem to get confused when something doesn't go according to plan. I eventually learned to switch everything off and walk away for half an hour.
Jan 02, 2017 | HP Office Equipment & Supplies
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Trying to print a 4 x 6 photo with HP Photosmart 130 I'm trying to print a 4 x 6 photo with HP Photosmart 130 printer, from my desktop HP Photo & Imaging software. It prints all but last 1/2...
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
Aug 02, 2011 | HP PhotoSmart 130 InkJet Printer
Printouts are missing top/bottom half of picture. Tried replacing cartridge and/or paper but to no avail.
make sure on your program that you are using to print your pictures, that you have the correct photo size. You could have it set for like a 4X6 for an example, where you might need a 5X7
Apr 18, 2011 | Kodak EasyShare Printer Dock Series 3
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Dec 18, 2010 | HP Photosmart 3310 Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
Printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan Logo
Seeker5211
Seeker5211
