Question about Xerox Office Equipment & Supplies
SCANNER FOULT SHOWING LL47
IN OUR SCANNER IS SHOWING SCANNER FOULT LL47
I have a 2004suzuki wagon and i have a ligth with a padlock though a car. The car wont start how can i resove this problem thanks jess
this may be an indication the the immobiliser is working and preventing the car from starting. Check that the battery in the fob key is good. Try and use a code scanner to reset the immobiliser in the CPU of the ECM. If there has been a disconnection of the battery at some time lately then that affects the immobiliser.
Oct 31, 2014 | Cars & Trucks
How can I reset the "tire pressure sensor foult" massege
You have to have someone with a scanner check it and reset it.
Oct 11, 2013 | 2006 Mercury Mariner
Scorpio scannig foult code p162d
You have an issue with the internal controls; Cruise control malfunction.
Oct 17, 2012 | Cars & Trucks
My park brack light , disk light and engine foult light com at same time and prevent my car from operating propertly
disconnect battery and join the leads together and leave like this for 5 mins then see what happens when you reconnect them ?'
Jul 02, 2011 | 2005 Jaguar S-Type
Im getting a 'message corrupt' problem with my new sony ericsson .its not allowing me to send a message nor showing any received one! i need immediate help.
ok ok just dont panic download sony ericsson update service and install it run the program it shoud itself guide how to update the phones firmware do it and the problem should be fixed if its not hardwares foult
Dec 02, 2010 | Ericsson Cell Phones
When I try to download software/driver for my HP Scanjet 5470c I get errormessage: error '80004005' /Driver/dr_country_select.asp, line 37 What to do? I think it is the HP pages that are at foult.
A highly recommended Registry Cleaner and Error Solver to fix Error 80004005 is Errorsmart which is available for free at http://www.SpeedUpMyPc.Info. It also fixes the dll files so you don't have to manually register them. A nice side effect is that it increases the computer startup speed by up to 70%.
Aug 15, 2010 | HP ScanJet 5470 Flatbed Scanner
Air bag warning light. sensor issue drivers side.
hallo
if your foult is driver side airbag and it is not blown out, you should check "clock spring" wires behind steering whell.
if foult is driver side belt tensioner, check conector underneeth driver seat.
on the end erase foult/s with diagnostic equipment.
Marko
Oct 08, 2009 | 2005 Peugeot 405
Nokia 6630 white light displey foult
the lcd needs to be replaced on the phone.
May 30, 2009 | Nokia N73 Cellular Phone
2001 volvo s-40
codep1618 indicates a failur in comunications between the engine control prosesor and the automatic trans axle prosesor.the ecm/pcm stores the trouble info as freeze frame 'and the check engine lamp(mil) will light.the mill will be turned off after 3 on the 3rd trip cycle if the foult is no longer present.the freeze frame info will clear after 40 consecutive worm-up cycle have ocurred with out a foult.
Sep 19, 2008 | 2001 Volvo S40
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
