Question about Hotpoint NVL333GY Gas Dryer
Vibration I have a Hot Point Dryer model# NVLR333GTOWB it started vibrating during operation can you please let me know what is going on? Thanks
  • 65 Answers
Normally, I find lint stuck in the fins of the blower that cause it to vibrate. remove the front panel to access blower.
Posted on Jan 27, 2009
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
Excessive vibration during spinning
I think it should be normal.One of our washing machines does it too.No problem so far.
Aug 05, 2012 | Malber WD1000 Front Load Washer/Dryer
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Help!! i want to build my own raised platform for my kenmore washer & dryer. i am unsure as to how deep to make it . by measuring the appliances i would think that 26'' should work. does any one have a...
the plat form should not be any smaller than the bottom of the washer or dryer so long as all the feet are or can bet set on the plat for then it will be up to you as how big you want it
Apr 13, 2010 | Kenmore Washing Machines
Vibration problem in gamegube gamepad
Hi!
I have solved the problem on my Gamecube controller now.
The vibration is working again as usual.
Thanks for assisting me, I have solved the problem after all.
Dec 10, 2009 | Logitech Cordless Rumblepad 2 Vibration...
Loud hum/vibration on acceleration - Saab 95 Linear 2.3t
I have the exact same issue. I can't seem to replicate it for the dealer and it is identical to what you are describing. PLEASE e-mail me if you figure it out or know anything. I want to get it fixed and it to go away! Thanks! Todd. Tm2200@aol.com
Jul 18, 2009 | Saab 9 5 Cars & Trucks
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Enging vibrating at idle
1) It is very possible your engine mounts can be worn, but
2) the vibration you feel may be also due to the idle itself degrading to the point that the car is shaking. Does the engine sound like it is getting ready to die? what is the engine rpm when you feel the vibration? You may just have a dirty throttle body. In this case, clean the throttle body plate and bore and the problem will go away.
3) did the problem seem to come on suddenly or gradually, if gradually, you may just need some plugs and/or wires, and/or cap/ignition rotor, etc. (a tune up)
4) Also, do you only feel the vibration when the AC system is on?
5) there are some other reasons for abnormal engine vibration at idle, but the above are some of the most common, and simpler to repair.
All the best with the repair!
May 10, 2009 | 1991 Honda Accord
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to tomagic3@yahoo.com
thanks
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Nov 02, 2008 | Tricity Bendix TM310W Electric Dryer
Hotpoint NVL333GY Gas Dryer Logo
523 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
