Question about Samsung DVD-R155
When I put a blank DVD-R in my DVD player with the intention of recording, I get the following message "The disc cannot be played, please check the disk" I have put several brand new discs in and get the same message. This is brand new DVD player.
2 Suggested Answers
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Hi i have just bought a samsung dvd-sr150m of ebay the problem is,i tried to put a to put a new tevion 4.7gb dvd rwto recorder a programme but a message came on the screen unable to record or play this...
Some DVD recorders don't like some types of blank discs. You could have two discs the same but made by different companys and it might only record to one. Also this recorder will only record to - discs eg. DVD-R, DVD-R DL and DVD-RW. Hope this helps.
Aug 16, 2008 | Televison & Video
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
In Summary:
Jul 10, 2007 | Samsung DVD-R155
Samsung DVD-R155 Logo
Jerry Greenberg
Jerry Greenberg
