Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe not hot enough
My maching pumps water at 160 degrees F. Should it not be hotter? The boiler was replaced a month ago, now this. Would a new thermostat fix this or should I return for another boiler? Thanks in advance.
  • 1,089 Answers
Hi
They should have checked the temperature before shipping it out. There is a sensor on the back of the boiler that has (depending on how old the machine is) 2 orange wires. In the wire or on the wire is a resistor. You can remove the resistor and raise the temperature about 6 to 12 degrees, but I think you need a new sensor.
Posted on May 27, 2009
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
Grundfos pump problems
I've just had a ideal i35 boiler fitted, the grundfos ump3 economic pump has failed / seized and has been replaced 4 times since the boiler was installed 7 months ago.
It has just stopped working again and ideal are refusing to attend.
any advise would be appreciated.
Aug 14, 2014 | Grundfos Pumps Grundfos UP15-29SF 1 12 Hp...
Symptoms bad thermostat
how to replace a water pump in a 2010 jaguar fx
Jan 04, 2014 | Measuring Tools & Sensors
My central heating is set to max 20 degrees but we keep coming home to find house hotter than that. The thermostat is in the hallway, the boiler and froststat (latter newly replaced) are in the integral...
Hi Lyn,
Had the same problem with my system. turned out to be the thermostat in the hallway. Mine is an older electro-mechanical type with contacts that open and close as the temperature changes. (these type of thermostats click as you rotate the temperature dial) What had happened was the contacts had stuck closed even as the temperature rose and thus the boiler kept going. I cleaned the contacts with WD40 oil and everything is fine again. If you have the same type of thermostat this may be the problem. Be aware that if you or anyone else removes the cover of these thermostats there is live mains at the faulty contacts, be sure to switch off the circuit feeding this thermostat or remove/switch off the fuse in the main fuse box. Alternately you could replace the thermostat. If you have an electronic digital thermostat then this solution is not valid.
Good luck
Nov 24, 2013 | Heating & Cooling
Installed a year-and-a-half ago, problems so far: thermostat replaced on hot water tank within one month of installation, one pump replaced, leaking plug in the front of boiler with Dunkirk rep never
Its probably time for small claims court and a new company to install good equipment. Have a couple different companies/contractors give an estimate and possibly expert advice/witness you would then be able to use in court so you can get reimbursed from a bad company. Hope it all works out.
Apr 20, 2013 | Dunkirk Q90-75 Quantum High Efficiency...
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
How can I change the thermostat?
There are two thermostats on the top of the boiler. One for steam and one for hot water. Three metal clips with screws hold the two thermostats in place. The clip between the thermostats does double duty. Look at the picture in the manual to see which is which. If you lost it, you can Google for the wiring diagram.
Unplug it. Let it cool. Take out the water tank. Take out the 4 screws tha hold on the top cover and then remove the top cover. Take the two wires off the thermostat. Take the two screws and clips off that hold the thermostat. Replace the thermostat, Install the screws and clips. Install the wires. Install the cover and screws. Replace the water tank. Plug it in, turn it on, and pump 4 to 6 oz of cold water out the steam wand into a cup.. Turn off the pump and shut off the steam wand with the tip under the water level in the catch cup.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
Hi! One of my friends has an old Vienna Digital coffee maker (Saeco). It works fine. The only problem she has is that her coffee is never hot enough. She has to put her cup into the microwave if she...
There is a thermostat that is stuck on the boiler. I would suspect that this thermostat has either:
1- A bad contact with the boiler. Contact is assured by thermal paste
2- The thermostat is faulty and gives false readings, thus preventing the boiler to heat the water enough.
Hope this helps
Apr 09, 2011 | Saeco Vienna Digital Coffee Maker,...
On my saeco vienna machine i hear the pump working but no water is coming through
Any water leaks following the pumping sound ?
If there is no leaks, I would try to get some hot water from the wand.
If there is still no water coming out, I would:
1-Decalcify thoroughly
2-Open the machine and take the inside out and verify the status of the water pipes going from the water tank to the boiler than to the wand and the brew unit ... to make sure there is no restriction.
3-Replace water pump
Jan 25, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
464 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
