Question about Grandstream BudgeTone BT-201 IP Phone
Grandstream budgetone 201 factory reset - Grandstream BudgeTone BT-201 IP Phone
Reset password for grandstream gxp1450
What is this and what does it do?
Sep 22, 2016 | Grandstream GXP1450
My nokia corporation 0168 mhave security code
How can i reset the security code of my nokia ce0168 ...
www.askmefast.com > ... > Code
... nokia ce0168? How can i get back my security code in my nokia asha ce0168 ....Ce0168 model 201 type rm 799 nokia 201 master code ยท Master reset code ...
Forgot the security code of nokia 0168? - Ask Me Fast
www.askmefast.com > Computers & Internet > Security > Code
You can get the master rese ... read more .... Code de reinitialisation nokia corporation 0168 ... Factory reset for lg ce 0168 and can t remember security code.
Nokia c e 0168 security codes - Cell Phone
Jan 13, 2016 | Nokia Cell Phones
How to unocked keypad
press *** on the keypad, then enter from the softkey. If the phone keypad was accidently locked you can unlock it without a pw, but if was intentionally locked with a pw the only way to unlock it is either with a pw or to factory reset the phone
Apr 22, 2015 | Grandstream GXP1450
How to reset admin passwod gxp285
The default administrator password is "admin"; the default end-user password is "123".
You would need to do a factory reset if those don't work, but beware all your configurations will be overwritten.
See instructions here P44 http://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Jun 27, 2014 | Grandstream GXP285
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
A wrong pass word was entered and the devise was blocked.how can i access the device again?
you would need to factory reset the adapter if you dial *** then 02 it will give you ip address now if you put the ip address into your main web browser it will pull up a configuration page for your handy tone you will see a tab on the left hand side that says reset click that and factory reset the device this should wipe out all current configurations on tht device
Oct 07, 2009 | Grandstream HandyTone 486 ATA (HTATA486)
Imate Jama 201 - No sound What should i do
probably remained open some java application. try to save all contacts and personal data and perform hard reset menu settings master clear.
remember back in the factory configuration and then you lose all the data you've added
Jul 09, 2009 | i-mate Jama 201 Smartphone
Grandstream password recovery
if you have a password reset disk use that.otherwise
you must use the password recovery software
Feb 14, 2008 | Grandstream GXP-2000 IP Phone
Grandstream BudgeTone BT-201 IP Phone Logo
85 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
