Question about Rotel New Original RR-1060 Remote Control
ROTEL RR-1060 volume buttons not functioning
It started to take a lot of pressure on Vol +, then on Vol -, now neither button will work at all. I took out screws but couldn't see any way to be able to look at the contacts under the buttons, that case is sealed.
2 Suggested Answers
SOURCE: Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
Navigon easy 40 no sound
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law.
The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it.
This happened to me and this was the fix, odd but true.
Also see if there is a turn by turn vol level in settings.
Hope it works for you.
Aug 12, 2012 | Navigon 40 Easy 4.3" Sat Nav With Western...
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
I can't get the volume loud enough to listen to the songs on the Eclipse mp3 player(2GB). How do I get the volume to work so I can listen to the songs?
The volume button is the one under the center pause/ play (>II) button.
It may be marked VOL.
The manual does not give anymore information than that.
Try using short press or press and hold to change the volume.
This is a common method for using two functions on the one button
Jan 31, 2011 | Eclipse CLD2 MP3 Player
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
Jun 11, 2010 | General Electric RCA-25424RE1 4-Line...
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Very low volume on 'handsfree' option; whereas the vol. for the line button can be quite loud
Hi.
The Volume function of that phone is controlled by the up down vol button on the phone. the only time it does anything is when that function is being used. ie. when you have the handset in hand the vol buttons control the handset volume, while the phone is ringing the buttons control the ringer volume etc.
Dan
Oct 09, 2009 | NorStar M5316 Phone, NT4X42 (Refurbished,...
Lost the volume control function from Compaq Keyboard
You should get it checked is this the Dell inspiron if it is the buttons are touch screen right?so you should be careful with it and dont push it hard
May 21, 2009 | Compaq Keyboard
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Rotel New Original RR-1060 Remote Control Logo
Top Rotel Televison & Video Experts
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
