Hisense HL42K16PL 42inch Full HD LED Television will not turn on
The tv will not turn on via the remote and there is no red light on the tv, so i can not turn it on from there either, i have checked if the power cords are in place and they are fine!
Shuttle83
  • 1139 Answers
SOURCE: jvc AV42PD20ES 42INCH TV
Hello gladwin6,
You may have at least a blown fuse. However you may also have other damage to your power supply. This often happens due to the voltage spike caused by the power coming back on suddenly. You can check to see if the fuse is blown, however once you change the fuse and if this does not take care of the problem, I would suggest that if you do not have a background in electronics, that you have a qualified technician take a look at your TV set.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 25, 2007
SOURCE: samsung s42sd-yd01 plasma television wont power up
i have also this problem 1 relay klikt than must klikt the second relay it do nothing
i see a few elco,s on the visibel boards who are dik the plastik is dik not the metal
to hot maybe
can this give the problems
somewone a solution for this tv ??
sorry for my bad englis
thanks
Posted on Aug 13, 2008
SOURCE: samsung hd tv will not turn on
Just wanted to confirm the solution (or atleast solution to MY problem).
Thank You to those who posted the solution to this problem.
I have a Samsung 52" HD LCD TV. I bought it 1 1/2 yrs ago and recently had been experiencing this problem of continual clicking and no video upon power up.
It would take approximately 3 - 5 minutes before eventually turning on. I noticed that prior to turning on, the clicking would get faster and the blue light at the base of stand would begin to get brighter.
So, based on the suggestions here, I opened up the back of the TV and located the Power Supply. I visually inspected the capacitors and in fact, found 2 of them that had a subtle but obvious bubble or protrusion on the top -vs- flat tops, like the majority of the caps.
These caps were 2200microfared, 10V rating. I went to my local Radio Shack and bought a higher rated version of the 2200 microfared caps (35V). I Replaced the old caps with these new ones and it solved my problem. :)
There were a couple of caveats though:
1) the higher rated caps were physically larger & had axial leads vs radial leads.
2) The leads of the larger caps were just thick enough to prevent them from being inserted in the board.
3) Rather then make the holes of the board bigger and risk destroying the solder pad, I used appropriate sized leads from some resistors that I had as extensions and soldered the new capactiors to the extensions. Of course you need to be aware of polarity and assure that the leads will not come in contact with each other or anything else on the board.
4) Capacitor Radio Shack p/n: 272-1020. Total cost of both was less then $10.
Hope this is helpful. I did take some pics of the capacitor location and board location. If anyone would be interested in the pics, you can email me @" me_n_bigbertha@yahoo.com"
Posted on Oct 13, 2009
SOURCE: My Polaroid TV TDA-03211C will not turn on. It has
power supply problem bad capacitors the red light is power to check cap inside
Posted on Mar 30, 2010
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Can anybody please help me with the 3 digit code for the hisense tv to activate my universal remote please.
Ok what kind of tv do you have? I need the make model ? And what kind of remote do you have?
Apr 30, 2016 | Hisense 40" Smart TV Full HD 1080p LED...
My hisense 42inch led has no power what can I do ?
I would send it in for warranty work if the TV is still under warranty. If not it's cheaper to purchase a new TV than to have it fixed. Esp this week with the Cyber Monday week sales going on.
Oct 08, 2014 | Hisense Televison & Video
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I jus bought a universal remote for my HiSense 32inch full hd LCD32v88peu and can't seem to find the code any help pls.
Hi, Try this and good luck
1. Turn the TV on.
2. Press the TV button on the top of the remote.
3. Press and hold SETUP until the LED light blinks twice.
4. Press 9 9 1 and the LED should blink twice again.
5. Press the POWER key on the remote.
6. Press CH+ repeatedly slowly until the TV turns off.
7. Press SETUP when the TV turns off.
Jul 26, 2011 | Televison & Video
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
My 32" Samsung lcd tv won't turn on, led is solid red
Apr 09, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
