Question about Envion Therapure Air Purifier TPP240
After vacuuming filter and replacing, it wont turn on
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
Hello, this is Ava with Think Crucial.
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 01, 2016 | Hunter Air Purifiers
Tip
Your vacuum cleaner doesn't suck much?
You have emptied the dust canister for many times. You hear the motor running, but it doesn't pick up much. Your vacuum cleaner is still OK...
If the motor was not running at the beginning, I suggest you read some other Fixya troubleshooting tip.
Now it's just TIME to replace these filters.
They come in set of 2, a first one has a cylinder shape and a second one is flat.
I recommend as a good consumer, you to first order a new set, cause this cleaning process may be spread over few days. Unless you wish not vacuum for a while...
After replacing with the new one under the cannister, here is how you RECYCLE the old one.
Important Safety Rules First:
  1. This procedure should be done only outside of your home. Stay away from all clean surfaces as hanging bed sheets, rugs, clothing, and open windows : cause one wind drought may give you more work to do ;-( !
  2. Always wear a safety mask, for obvious reasons: since we don't know what's in there: breathing any dust is very hazardous to your health. Better be safe than... sorry :-(
  3. You should wear rubber gloves and old clothes. Why would you get your hands or your clothes dirty?
Brush out all you can off the cylinder and the flat filter with a cleanup brush or disposable rag.
Soak the used vacuum filters in a disposable container (yogurt or ice cream) ;-) filled with soapy water (1tb spoon dishsoap in 1/2 quart or liter of water). Soak for 10min. Rince once. Refill again with soapy water and let it soak overnight.
Rince it now with clear wather. Looking through it you shall see most of the dust should be gone.
Do not replace these wet filters the same day in your vacuum cleaner because it would obviously damage it's motor. Why do you have to hurry for?
Let it DRY in a warm place or in direct sun for another day! Store it until you are ready to replace it again.
Your have RECYCLED once more! You may do it as a few more times as long as it doesn't affect the performance of your vacuum cleaner.
This process could be applied to many more vacuum cleaners and some household items we normally throw away.
GB
on Dec 16, 2015 | Shark Vacuum Cleaner HEPA Filter X9602H...
Uh70600
Take the filters out and turn the vacuum on, if it will stay running without the filters in it you need to replace the filters. Filters should be replaced every few months. Clogged filters still pick up some dirt but miss a lot plus it causes the motor to run hot which will cause damage to the motor reducing it's life.
Nov 20, 2013 | Hoover UH70600 WindTunnel MAX Bagless...
Honeywell 703 central vacuum seems very hot after using
David
I recently purchased the same unit and had the same issue. I have since received a replacement and realized where the problem was for me. when Honeywell packages the unit for shipment they place all the extra parts including the muffler inside the canister. If the box is inverted in the shipping process than all those items create pressure on the filter/bag that seals the dirt canister from the suction side of the motor. In my case the bag was damaged/torn from the items inside during shipment and I didn't realize it. The motor then sucks a lot of hair, dirt and debris into it's cooling blades causing extra load when it turns. In my case it was extreme enough excess load that it overheated the brushes and covered everything in black soot. So...if it runs hot i suggest you inspect the bag/filter for holes. best of luck ..it worked for me
Aug 28, 2013 | Honeywell 4B-H703 Central Vacuum Power...
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
We can't really afford to replace our F100F2002 Honeywell filter. Is there any way to clean it ourselves?
You can vacuum it but its not recommended by the manufacturer. Try going online to find replacement they willl be a lot cheaper than if you called a HVAC company and bought it through them. Vacuuming the filter will buy you some time. If this is helpful please rate me.
May 19, 2011 | Honeywell F100F2002 Air Purifier
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Envion Therapure Air Purifier TPP240 Logo
46 people viewed this question
Top Envion Air Purifiers Experts
Are you an Envion Air Purifier Expert? Answer questions, earn points and help others
