Question about Dishwashers
Washdisher drains and heats water ,doesn't start cycle
  • 234 Answers
SOURCE: Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Posted on Apr 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
Posted on May 21, 2009
  • 228 Answers
SOURCE: bosch maxx 1100 WLF 2260uk.it takes water in but
no drum rotation motor brushes failed cheap and easy to replace.
Posted on Dec 15, 2009
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool dishwasher Model DU1345XTVQO, Serial
Hello, Welcome to FixYa.
Based on your post I understand you have a drainage problem with a Whirlpool dishwasher. t
ypically with these machines having poor washing and incomplete draining it can be chalked up to obstructions in the sump assembly. Here's how to inspect it and clean it if necessary.
Try this link if you think you're not too confident. They aren't pros, but it is a good guide for accessing the sump assembly relatively easy. This combined with my tutorial you should be fine.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
NOTE: Pay particular attention to the area where I've placed the arrow. It is a back flow check valve and can get debris stuck in it allowing water to back flow into the sump after the drain cycle ends, hence you get water left behind.
The other thing to inspect is the drain. The proper drain should actually be tied up at least as hi as the top of the dishwasher and the closer to the machine the better, but if it drains into a sink or disposer right next to the machine as long as it is tied up under the sink it should be fine...you also want to rule out any kinks in the hose of course.
Now you'll need to run a "reset" test sequence to observe it's performance. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the pump itself is at fault...we'll cross that bridge if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 24, 2011
mc1bean
  • 3053 Answers
SOURCE: The coffee maker heats up the water, but it
It sounds like the pump has possibly gone out , if that is the case,the pump cost and time and hassle to put new pump in ( IF, you can get it) would not be worth it on that type of machine. Might be time to hit the sales for a new one. Sorry, mike ( Mr Bean)
Posted on Jun 10, 2011
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
Dishwasher stopped in the draining cycle and will not start back up, even after turning thye daqil to start a wash
Hi
Daniel
Jun 15, 2011 | Frigidaire 24 in. FDB221RF Built-in...
Dishwashers Logo
Top Dishwashers Experts
