Question about HP Photosmart D7160 InkJet Printer
Printer cannot grab paper,
The paper dock is full but everytine I try to print it tries to "grab" the paper but it can't and keeps saying "printer is out of paper". Any suggestions?
  • 1 more comment
  • Anonymous Nov 21, 2007
    Printer cannot grab paper - keeps saying it's out of paper. Have tried shutting it off, filling the entire tray and just using one piece. Nothing works.
  • Anonymous May 20, 2009
    my printer canon pixma ip1880 problem paper cannot down
  • Anonymous Mar 15, 2014
    printer will not grab the paper
  • 32 Answers
The rollers in these printers go bad all the time. Your best solution would be to take it to a local printer shop and get the rollers replaced.
Posted on Jul 19, 2007
SOURCE:
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer dock does not pick up paper.
I cleaned the wheel as a previous user had advised - I also pushed up the metal catch that sits under the printer and lifts the paper cartridge and it started to print. My replacement printer however didn't respond to this, however at least I have one that works.
For how long it will continue to do so is another question...!
Regards,
D
May 29, 2009 | Kodak EasyShare Thermal Photo Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
The dock doesn't grab the paper. and if i help it, it just jams up
I had the same problem. Kodak support advised to take a damp lint free cloth ( I used a white handkerchief ) and wipe clean the center roller that grabs the paper. You can rotate the roller manually until you're satisfied you've cleaned it all. I just wiped it right to left several times and all was ok again. I didn't see any residue at all on the handkerchief but there must have been something that was there. Anyway, I think this'll work for you also.
Now if I could only figure out why my printer dock plus is only printing the lower part of pictures even though I installed new ink cartridge. Kodak advised to tighten slack in cartridge. There was not any noticeable slack. Still a no go.
May 17, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Try to clean the rubber rollers with lint free cloth. Make sure you are using Kodak Xtralife paper. At the back of the paper it should say "Xtralife".
Apr 02, 2009 | Kodak EasyShare Thermal Photo Printer
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Printer dock won't print. Says ''no Paper,'' but is full
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Kodak EasyShare Thermal Photo Printer
Out of Paper
make sure that the paper is kodak xtralife with perforated tabs, otherwise the printer will really not pick it up and if it would - it's gonna be a really bad print
detach all the things that are attached to the printer.
grab a piece of lint-free cloth, wet the other end and leave the other end dry
clean the roller horizontally
use the dry end to dry up the roller and watch for water build ups
have at least 10 photo papers in the paper tray
slide the paper tray back into the printer
plug the printer onto the wall outlet, wait for the initializing sound
put cam to the printer dock
print a picture
Jan 20, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Printer does not print
I think trying the solution i gave on this post should solve your problem also http://www.fixya.com/support/t122427-printer_printing_wierd_things_not
Nov 11, 2006 | HP DeskJet 722c InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
159 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
