Question about Panasonic Dp-4530 Copier - Workio Dp4530 Network Printer
Panasonic dp-4530 error j42 - Panasonic Dp-4530 Copier - Workio Dp4530 Network Printer
  • 19 Answers
SOURCE: Keep getting error code E07-27
E07-27 is a problem with the finisher tray lift motor. Make sure that a trash can is not under the tray. Have also seen screws work there way loose causing the tray to bind. If neither is your problem, you will have to call a service provider. Temporarily you can turn the power off, separate the finisher from the machine, unplug the connector, and turn power back on. You will not have a finisher but you can make copies until it is serviced.
Posted on Feb 06, 2008
  • 100 Answers
SOURCE: for copier panasonic workio dp-4530
you mean all departments codes?
if you are the person incharge of copier on your company,
1) press function, gen settings, depart. mode,
2) input the 4 digit key operator code, the search for department mode again.
3) press the department code on the left side of the touch panel then you can erase each department code.
i hope hope this is helpful
Posted on Aug 21, 2008
checkitright
  • 1362 Answers
SOURCE: Panasonic DP 4530
E4- 02 Paper Jam 1. Paper Jam in Fuser Unit.
2. Paper Exit Sensor 1 or 2 is disconnected.
3. Paper Exit Sensor 1 or 2 is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
Posted on Oct 20, 2008
  • 100 Answers
SOURCE: dp 4530 error code E03-40
e3-40 usually appears when the copy density sensor is dirty. it is located at the bottom of the drum unit. you may pullout the drum unit from the machine and disassemble it to clean the copy density sensor board. it is a small PCB that has two proximity sensors.
pls. keep in touch if you still need an assistance
Posted on Dec 04, 2008
  • 224 Answers
SOURCE: what does error code E05-11 mean?
switch off then on, pull top cassette out slightly. this will provide a temporary solution. a service technician will need to see the machine.
Posted on Mar 30, 2010
Panasonic 4530 e03-40
try to clean the copy density sensor near drum unit
Jan 01, 2014 | Panasonic Workio DP-4530 Copier
Tip
Panasonis Workio DP-4530 service manual?
Hello
My name is Edo and I am IT for UN mission in Afghanistan. We have copier Panasonic Workio DP-4530 and it is heart of our design office. We use copier for publishing documentation, for copying and printing. We can find any normal service in Afghanistan. The nearest place for repairing is Dubai.
I have experience with copiers and I want try to fix our copier. Currently, our new problem is error “clean fusser web”.
I need only if anybody have service manual in pdf or similar format. I will be very appreciated if anybody can help us. Your any advice is welcome as well.
Mr. Edin Husejnefendic
IT Systems Manager
Vertical Structures Unit
Afghanistan Operations Center (AGOC)
United Nations Office for Project Services (UNOPS)
House No. 6, Behind Emergency Hospital
District 10, Shar-e-Naw
Kabul, Afghanistan
Mobile: +93 0799 303-021
http://www.unops.org
on Jan 06, 2008 | Panasonic Workio DP-4530 Copier
What does error code E05-11 mean?
there is a communication error on the device most propably caused by a problem with the large capacity tray feed unit loom. there is a techinical update for this problem and you would need a technician to attend.
May 15, 2010 | Panasonic Workio DP-4530 Copier
Mar 29, 2010 | Panasonic Workio DP-4530 Copier
Need help updating the SMPT server ip for a dp - 4530 panasonic printer
yep!
you may try this:
  1. press FUNCTION key
  2. select FAX/EMAIL SETTINGS
  3. select key operator mode
  4. input the key operator code 0000
  5. find fax parameter
  6. select SMTP SERVER IP
that's it :)
...this will work assuming the dns function is disabled.
Dec 16, 2009 | Panasonic Workio DP-4530 Copier
Printing envelopes from bypass tray
Yes insert and selct the thick stock
Dec 01, 2008 | Panasonic Workio DP-4530 Copier
Mirror image
sorry, no you can not
Nov 25, 2008 | Panasonic Workio DP-4530 Copier
Printing to copier
ah, probably it means that the department ID is activated on your copier.
go to the printing preferences on of the panasonic dp-4530 on your pc, the click the job type tab.
on the space provided you may type in the code that you use during copying or ask the person incharge on your company re department code.
Aug 18, 2008 | Panasonic Workio DP-4530 Copier
Jan 30, 2008 | Panasonic Workio DP-4530 Copier
Panasonic Dp-4530 Copier - Workio Dp4530 Network Printer Logo
41 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
