Question about Vehicle Parts & Accessories
How do you change the tail lights in a 2011 Durango?
    Genius:
  • Vehicle Part... Master
  • 1,669 Answers
There are a whole bunch of lights in the back. To change the lights under the "trunk" lid you need to remove the inside panel at the bottom (there is no need to remove the whole panel unless you intend to change the middle brake lights). Then, the sockets are exposed and the bulbs can be pulled after 1/4 turn counterclockwise on their sockets. The outer bulbs are accessable from the inside lower side panels being removed and the same about the sockets...
Posted on Jan 22, 2013
Dodge Durango problems
2012 Dodge Durango problems - Dodge Durango Forum - Forums and ...
www.durangoforumz.com > ... > Newbie Check-In!
Apr 12, 2012 - 8 posts Purchased a 2012 durango citadel, less than 2k miles, when acceleratring transmission/engine jerks in and out of gear, engine light comes on ... 2012 Durango R/T Transmission Problem
Dec 13, 2011
New 2012 Crew Computer Problem?
Dec 11, 2011
More results from www.durangoforumz.com
Aug 30, 2015 | Dodge Cars & Trucks
Turn signal not working
TAIL LIGHT NOT WORKING
It can be faulty tail light bulb or its issue with tail light control switch or its wiring's are short.
Check the voltage at fuse slot of tail light.Do you receive 12 volt there.If not,then it says tail light switch is not receiving power supply.
There are few help links related to your problem.I suggest you refer the list and check the help links.Click the link below:-----
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR 4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
1994 Toyota Camry: Bypass Tail light Relay Circuit?
http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2008 Toyota RAV4: Replace Tail light Lens Cover?
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
These details will help.
Thanks.
Feb 15, 2013 | 2004 Pontiac Grand Am
The tail lights do not work. The headlights, blinkers, and brake lights work. I checked the fuses and they are all good.
1994 Toyota Camry: Bypass Tail light Relay Circuit? http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2003 Chevrolet S10 Tail light Fuse http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
--------- Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
---------- Car Tail Lights Not Working?
Turn Signal Not working http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
---------- Right turn signal not working on Pontiac Car?
Turn signals not working on 1987 Jeep Wagoneer? http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
Thesedetails will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
2001 dodge durango /tail light troubleshooting
Open the rear door, locate the two screws next to the tail light. They will be philips head. Take them out, pop off tail light, unhook light harness. Reinstall is opposite of removal.
Sep 01, 2012 | 2001 Dodge Durango
Change tail light bulb 2011 street glide
Hi Anonymous, remove the two screws securing the tail light lens then remove the bulb. Have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 14, 2012 | 2011 Harley Davidson FLHX Street Glide
I have a 2000 Dodge Durango I bought about 4 hours ago. The tail lights do not work but the brake light and turn signals do. Also the dash lights do not work. The dash lights came on when I hit the...
The odds are the one fuse is blown for the dash and the tail lights. And the wrong bulb may have been put in for the brake light. The brake light is feeding back into the tail light circuit causing the fuse to blown out.
Change out the bulbs with OEM bulbs and replace the blown fuse. That should fix the problem.
Apr 16, 2010 | 2000 Dodge Durango
My brake lights do not work but my tail lights and turn signals d
Check the fuse box and test the brake switch on the brake pedal.
Aug 07, 2009 | 2000 Dodge Durango
Light problem in 2003 durango
well yes i would check all the fuses first
Nov 10, 2008 | 1999 Dodge Durango
Vehicle Parts & Accessories Logo
725 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
