Question about Philips Sony KDF55WF655 KDF55WF655 Lamp with Housing XL2200
Yellow screen Picture is yellow. Have tried everything to get the picture right in the menu.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
My picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
Posted on Jan 30, 2013
Sound it on and can change channels, but no picture. The screen is showing the set-up mode. I have called the cable company thinking it was the box, removed the batteries from the remotes, re-booted...
try reset to defaults:
  1. Press the 'MENU' button.
  2. Press the cursor down to select SETTINGS.
  3. Press cursor right twice.
  4. Press the cursor down to select RESET AV SETTINGS.
  5. Press cursor right on START NOW. Press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Feb 20, 2010 | Televison & Video
When i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Jul 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
We have a yellow tint in the picture, it is worse
Yes, It could be either your video board or your dmd board, go to the service menu and if the yellow tint is still there, it's your dmd board, if not it will be your video board
Jul 09, 2009 | Sony KDS-60A2020 60" HDTV
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Philips Sony KDF55WF655 KDF55WF655 Lamp with Housing XL2200 Logo
63 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
