Question about Brother CP6500 Sewing Machine
Engine revs but doesn't sew
Brand new sewing machine, threaded fine...doesn't sew
  • Brother Master
  • 7,365 Answers
Then the machine needs to be taken back and get another one
Posted on Jan 22, 2013
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: i have a brother ps57 sewing machine
MY PROBLEM IS NOT WITH LS-2125 MECH SEWING MACHINE
Posted on Jul 06, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
Thread doesn't loop, it will not sew
try changing the needle
try rethreading the machine top & bobbin
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the sewing machine timing
needs to be checked at a sewing machine shop
Oct 03, 2012 | Brother CE5000 Computerized Sewing Machine
My needle thread doesn't break, but when I go to sew, it unthreads itself.
make sure to keep long thread tail for the top & bobbin
of 4 to 6 inches & pulled behind the needle
Aug 04, 2012 | Kenmore 15516 Mechanical Sewing Machine
My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Jun 07, 2012 | Singer Confidence 7467 Mechanical Sewing...
I can't get my bobbin thread to pull up on my brother bc-1000 sewing machine
have you tried changing the needle?
if you have & it doesn't help then it's possible that the machine is out of time & needs to be serviced
May 16, 2012 | Brother BC-1000 Computerized Sewing...
I am trying the tention,, and topt is fine,,under neat is loose
try adjusting the top tension
make sure the needle can be used for sewing fleece
try rethreading the machine ,make sure each thread guide is used
if you try changing the top tension & the machine doesn't respond to any tension setting then maybe the tension dial needs to be replaced
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is wound correctly
clean under the needle plate & in bobbin area for lint or loose threads
Apr 01, 2012 | Brother Sewing Machines
When I put the pedal down, the bobbin jams, and cuts the thread
make sure the needle & thread & fabric are correct for each other
make sure ever thread guide is being used
Apr 01, 2012 | Sewing Machines
Can't sew because my bobbin doesn't work
it's very possible that the sewing machine is out of time
sewing machine shop can tell you for sure
Feb 26, 2012 | Brother XL-2600I
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
The bottom tension on my Pfaff 2056 sewing machine is loose and keeps jamming up.
check the top tension try a 3 or 4 but I wouldn't go any higher than 5
also put in a new needle
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread doesn't come off the thread take up lever
Aug 10, 2011 | Sewing Machines
Brother CP6500 Sewing Machine Logo
55 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
