My lapyop cannot be turned on samsung rv410
I just leave it charging.then i keep it becaused itb full charged now..after two day i opened it and the problem started ..i cannot open it,,
    Genius:
  • 1,669 Answers
It is possible that the charger overcharged the battery and damaged it. Remove the battery for a few hours and reinstall it!
Posted on Jan 22, 2013
SOURCE: my laptop have a light that it is charging but couldnt open.
PUT OUT THE BATTERY OF LAPTOP AND REINSART IT THEN START THE LAPTOP OK
Posted on Apr 23, 2009
  • 60 Answers
SOURCE: initial trouble charging EEE
Try taking out and putting back in battery. also check to see if contacts on battery has tape on them.
Posted on Jul 23, 2009
JaxPlanet
  • 922 Answers
SOURCE: my samsung q320 keeps freezing when I leave it
Overheating: Turn it off and use a can of compressed to air to force dust out of vents. I recommend doing this twice a year for notebooks and once a year for desktops.
Bad driver, probably the graphics driver: Start up in Safe Mode. If it runs without locking up then remove drivers until it runs normally.
Start with the graphics driver. If that doesn't work then remove other drivers.
Make sure that you use the latest drivers from Samsung's website.
Please vote for my solution if it helps.
Posted on Apr 19, 2010
  • 2246 Answers
SOURCE: i want to open the case because the charging port
open srew all of it
Posted on Jan 03, 2011
budmrtn
  • 11361 Answers
SOURCE: after totally using up my laptop battery , I
So the PC works fine without the battereis installed. The batteries are more than 3 years old?
Posted on Jan 13, 2011
My samsung tablet will not charge and will not turn on
take back cover off and pull battery out for awhile about an hour then put back in, leave off but put on charger,let charge until is full , also check to see if wall charger unit is faulty by plugging it in to another outlet. if either fails take it back to where you got it from and get a new one
Sep 04, 2014 | Samsung Galaxy Tab Tablet PC
My 1999 f 150, I just replace the starter2 days agoit drains the battery down 2 days later.I charged the battery.now when I turn the key to start it won't do anythingnot even click at selenoid.I tried...
I'd use digital multimeter across battery posts, everything off, the generic spec for a full charge is 12.6 volts. Leave the meter leads touching the battery posts, have helper turn key to crank, what is the reading, It shouldn't drop below about 9 volts. If it drops down to almost zero, I'd have to test the battery. If it is open top battery, where you add battery water, you could use digital multimeter to check each cell, 2.1 volts.
You could do other checks? Maybe something is making the engine hard to turn over?
Feb 13, 2018 | Cars & Trucks
My Samung P3 will no longer keep a charge. I can leave it on the charger all day, then turn it on and the display shows a half charge. After which, it will just shut off saying battery not charged. What...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Samsung YP-P3JCB Digital Media Player
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
Unit got hot and stopped working properly
Nope! It may be the way you treat it
1) do not leave it in a hot car
2) do not plug it in and start the engine.
Goodbye SIIREF chip
3) do not just charge itb in the car Charge it from an AC or USB source first.
Please rate our help to keep the FREE service online ++++
Aug 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
Water damage/charging problem
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Dec 01, 2008 | Samsung SGH-T619 Cellular Phone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Keeps shutting off randomly
Dear if ur phone stuck on samsung logo and not go further then mostly its prob from software if u can make urself other wise contact to the technician.
Mar 27, 2007 | Samsung SPH-a660/VI660
When the EasyShare digital camera is not in use, and the battery is fully charged, can I leave the camera (turned off) in the dock?
The EasyShare camera dock automatically stops charging the batteries after it registers a full charge, so it is fine to leave the EasyShare digital camera on the EasyShare camera dock for short periods. However, leaving the camera on the dock for longer periods (days or weeks) is not recommended because this can cause problems with your camera and the batteries.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
