Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Tub doesnt drain
The tub does not drain
  • Fisher and P... Master
  • 17,130 Answers
Click on : Filters
Posted on Jan 22, 2013
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
My Maytag bravos doesnt drain& shows a code that
you have a stuck impeller (fan) in your water pump: use a hose shutoff clamp tool on the tub to pump hose above the pump to close off the hose and prevent the tub from draining then: remove the pump screws and, remove the (sock?) that is jamming the impeller and reassemble the pump remove the hose shutoff tool and, start the machine in "drain" mode the tool can be found at any autopart store in the radiator repair isle
Feb 04, 2013 | Washing Machines
Washer doesnt spin unless you open lid and close it, when you open tub will move a little and after closing lid spin will start
They way they work is during the drain time the tub is supposed to be locked, then the timer is suppose to have a built in 10 second pause to the power for the motor , where the tub unlocks to spin as you have see in the slight movement its unlocking. If the timer doesnt pause the power to motor its not unlocking and i highly suspect the timer needs to be replaced
Gene
Aug 03, 2011 | Kenmore Washing Machines
I can see outside of tub get wet and it leaks by the drain..its brand new..only does it when its drained after being filled to a high level..is it cracked or something? can't see any but dont know what...
If it only leaks when filled to a high level, the rubber washer behing the overflow plate is misaligned or missing. this plate is on the tub wall above the drain, and hld in in by 1 or 2 screws.
Oct 05, 2010 | Jacuzzi Home
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
Tub doesnt spin after wash or rinse cycle
if it goes thru the wash cycle , is NOT a belt problem , what could be is a sensor switch located underneath where the door closes , its like a latch switch for security when it goes to spin, hope its helpful AJ
May 14, 2008 | Washing Machines
When i press the start button the door will lock like everythng is going to start up and then 4 or 5 seconds later it unlocks and doesnt start
sounds like it is locking fine but is stuck on system check. if there is water left in tub then check drain pump to see if it is trying the pump at all. at this point the machine is doing a quick self check and looks at water level in tub. Usually this is when it sees water left over, tries to drain it and cant. if pump runs then its clogged. if it doesnt run then its bad. but check by draining water and or going into diagnostic. more info about this is in the tech sheet located at bottom of machine behind kick panel. here you will also see the pump.
Mar 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
Won't drain - drain light flashing
take drain hose off ,put end in pail, then try pump out.
if it doesnt drain check your pump
Jan 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
