Question about Acer P1165 DLP Projector
Dlp pd100 rest button
Reset
Acer dlp power shut off after a few minutes on
That's typically caused by the thermal protector. If the fan is running normally and there filter (if there is one) is clean, then the thermal sensor has probably gone bad. It will need to be sent to a repair center.
Jan 24, 2014 | Acer PD100 DLP Projector
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
Acer Multimedia Projector PD100 DLP overheating problem
blow the dust out of it with canned air, make sure the fans are all spinning. this should remove the causes of overheating. if it still says that it is overheating, replace the thermal sensor (usually near the lamp or the lamp fan).
Jan 12, 2010 | Acer PD100 Multimedia Projector
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Computer wont recognize DsR-pd100
didn't you get a driver disc?...
Please don't forget to rate me "FIXYA"...thank you!
Mar 04, 2009 | Sony Dvcam DSR-PD100 Camcorder
Acer PD100 overheating
I found that by resetting the factory defaults the problem goes away. I have experienced this issue a few times after attempting to correct colors.
this projector does not have the best picture or color quality.
May 07, 2008 | Acer PD100 Multimedia Projector
Samsung DLP
First try a "hard rest" , unplug tv for 5 minutes then plug it back in when you go to turn it on hold the power button in for a minute or until you hear a beep , if that doesn't work , could several things , let me know if the hard reset works first.
Robby
Apr 17, 2008 | Samsung DLP HL-P5663W 56" TV
No Signal
Try it with 75Hz for the second monitor and use the VGA input.
USB/serial is only for configuration.
Thomas
Feb 19, 2008 | Acer PD100 Multimedia Projector
Acer P1165 DLP Projector Logo
20 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
