Question about GE GSS25LGM Side by Side Refrigerator
Water dispenser does not work
I have a GE GSS25LGNB side by side fridge. The water dispenser stopped working, although the ice machine still makes and dipenses crushed and cubed ice. When you press the back for the water, it makes the initial sound like it wants to work, but nothing comes out. Almost sounds like it is clogged. Any ideas? Thanks
  • 410 Answers
Most likely the water line for the dispenser has frozen in one of 2 places. the first place to check and the easiest is the water tank behind the crisper drawers in the fresh food compartment. what i would do is use a hair dryer to warm the tanke and see if it will start working again. the next place that is common for it to freeze is in the freezer door. the only way to fix this is to leave the door open for a while to allow it to thaw out.
If I'm not mistaken I think there is a recall for some of the  GE sxs refrig that addresses the water line freezing in the door. you may want to all GE and heck on that. good luck peyton
Posted on Jan 27, 2009
  • Julio Novelo Sep 25, 2011
    Also check that the plastic water lines under the back of the unit (after the water solenoid valve and back after the water filter). They seem to become hardened and crack after the condenser has blow hot air across them over the years. If you need to make a correction, just to go Home Depot and purchase 3/8" OD tube and 2 1/4"-5/8" clamps. Just cut off a short length of 1" from the old one to connect back into the water solenoid valve. Use the clamps to connect the new tube to the old piece of the plastic tube, and shortened tubing coming down from the fridge to the door. Leave only a 1" stub to connect the new tubing. Check for leaks. Total repairs came down to $5.28. Good luck!
Water dispenser on fridge stopped
part # we49x10173 door heater.
Jan 19, 2010 | GE Refrigerators
I possess a GE Fridge model No. PCG23NHSBFBB (2 years old)and although the water dispenser is fine, the ice maker has stopped making ice cubes (the the dispenser tray has no ice in it)
i guess the ice try is completely dry.. this tells me that your solenoid has gone. unfortunately the only way to fix it is to replace the solenoid.if its not the solenoid it will be your water pump. both will require a technician, hope this helps
Nov 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
276 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Brad Goodale
