Question about Zenith DVP615 Portable DVD Player
Check disc message
It starts up and then stops spinning and the message "check disk" comes on. This is a new unit. It will play CDs with jpgs.
  • Mustafa YILDIRIM Jul 23, 2007
    Unfortunately that suggestion not solved my problem but he insistently request the payment...I wonder if I payed what will be?
  • 139 Answers
Sometimes the Spindel Comes lose from the Platter,Put one small drop of Super glue,Where the Center pin on the Platter is let dry for ! Hour,Should restore full operation...
Posted on Jul 19, 2007
CDs change without playing. Installed new motor and starts to spin and stops, and cycles through the cartridge.
Check to see if the laser lens is still on the laser!
If not see if its in unit and glue back on with radio/tv cement(don't super glue)! If don't work replace the laser.
Apr 11, 2010 | Pioneer PD-M603 6-Disc CD Changer
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Unknow Disk - Please check disk again ERROR MESSAGE. Have tried previous burn disks the work no problems in the DVD player..... BUT disks I have burn as of today keep coming up with the above error...
The problem is you need to replace the laser assembly if the disc is spinning and not being read, or if the disc isnt spinning, you need to replace the mpeg printed circuit board attached to the laser assembly. Good Luck.
Jul 18, 2009 | GPX PDL805 Portable DVD Player
Samsung DVD player when disc put in after trying to load it comes up with a message disc error on all discs
it can be two possibilities. 1)either the disk is faulty.check out in another player or drive and confirm whether the disk is properly working. 2)or the lens in the drive which reads the disk is either faulty or got dusty.in the electronics shop you get lens cleaning cd.insert that in your drive and play it.it will spin for a period of time and stop.then insert your dvd disk and check out if the same problem.then drive inner lens is faulty and needs replacement.
Jul 11, 2009 | Televison & Video
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD player fails to read CDs Sharp CD BA150 3 Disc Rotary Charger System : Issue; CDs that are loaded into the trays do not read/play, even though they did previously. Most disks will spin a little while...
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Jan 25, 2009 | Audio Players & Recorders
One more Time CD Jukebox Skipping
The fault is one or the other unit unless you have some sort of physical drag on the CD. There is a problem playing copy CDs too. Some work some dont.
Jan 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
Message "check disk"
Given that you have checked the owners manual for possible solutions & have tried more than one DVD, then the problem sounds like corrupted software in the player. You should return the unit for a replacement.
Jul 12, 2007 | Zenith DVP615 Portable DVD Player
Panasonic SA-AK330
Change the spin motor disc
Jun 08, 2007 | Panasonic SC-AK330 Shelf System
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Zenith DVP615 Portable DVD Player Logo
142 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
