Question about Bravo SD-20 Car DVD Player
Bravo sd-20, running thru amp as stand alone DVD, sound is muffled...monitor & all other functions are fine...plays movies...just the sound muffled any ideas?
Have the DVD running to an Amp then 4 speakers. Not using the screen audio. All of a sudden the sound started sounding muffled almost muted. Checked the fuse, no issue. The amp is fine too. Any ideas?
PROBLEM playing sd card
The slot is for playing many, but not all SD cards. What movies do you think it should "read"
Go to page 20 of the users manual
http://www.manualowl.com/m/Magnavox/NB500MGX/Manual/254277?page=20
Mar 20, 2014 | Magnavox NB500MGX BluRay Player
BurnRdeluxe. just installed, how do i burn a dvd
if you want to burn a movie in a stand alone dvd player you need to convert the avi to dvd .vob format first.
If your dvd can play divx along with vob (dvd) format then just burn the avi using the data dvd function you maybe able to put 3 or 4 movies on a 4 gig dvd. This will not work on a stand alone dvd player.
Oct 01, 2009 | Pearson Software MAGIX CD & DVD burnR...
Need info
yes and no. wou will need a vga to RCA video adaptor, then you will need to get something to play the sound through. after thats sorted out it should work. I use my monitor to play my xbox360 using external speakers
Jan 27, 2009 | Gateway FPD1975W 19" LCD Monitor
The speach during a movie sounds muffled
Please download Instruction Manual of DAV-DZ260 from Sony Support and go to page 25 and select appropriate sound option.
The disc in player doesn't match with current sound selection thats why you hear muffled sound.
Thank you.
Dec 16, 2008 | Sony DAV-SA30 System
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Bravo OHS-085 Car DVD Player, no sound comes through. wired with instructions from dvd player, what can we do? Is the player faulty?
Have a Bravo DVD van monitor. Sons pushed some buttons on set and now sound will not play through van speakers. How do I fix this issue?
Nov 27, 2008 | Car Audio & Video
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Muffled voice track on JVC TH-C5
It's an audio setting you will need to change. some movies are decoded in dolby and some by dts. This means you will have to adjust accordingly depending upon the source of audio in the movie. a double d is dolby's trademark and dts is regesterted trademark for the company "digital theater sound." The icons are on the dvd usually. Anyways, find the set up button on the remote control and use the directional arrow keys on the remote; up, down, left, or right to adjust for best sound. the thc5 will have the most function on the surround settings, movie, music, and all st. try a sequence, than repeat until desired sound is heard... good luck
Dec 26, 2007 | JVC TH-C5 System
Power won't stay on.
There should be Two power wires connected one to constint power and One should be hooked to the power for ignition I also believe that there is a saftey that turns its off after so many seconds, There should be a way to disable that function in the owners manual, I sure Hope that helps you out Happy Holidays If not Lets fix it somehow just write back and let me know if that works..
Dec 14, 2007 | Bravo SD-20 Car DVD Player
Bravo SD-20 Car DVD Player Logo
16 people viewed this question
Top Bravo Car Audio & Video Experts
Tre Elkins
richie46
Are you a Bravo Car Audio and Video Expert? Answer questions, earn points and help others
