Question about Atari Civilization III: Conquests for Windows
Civ III conquest - Atari Civilization III: Conquests for Windows
I need to replace the game disc for civ 3 . who do I contact?
Atari bought out Infrogrames and currently there is no support offered for Civ 3 at all so if I were you I'd go to Amazon.com and pick it up for super cheap. $6.50 for brand new... 50 cents for used.
Here's a link:
http://www.amazon.com/Civilization-3-Gold-Pc/dp/B00009THMU/ref=sr_1_1?ie=UTF8&qid=1338599905&sr=8-1
May 29, 2012 | Infogrames Entertainment Civilization 3
Problem running Civilization IV with Windows Vista
Okay, i play Civ IV on my system and i run Vista as well. Your best bet is the tweak with the compatibility. Find the install folder and look for the .exe that launches the game (civ.exe i think, don't hold me to that though). Right click on it and click on properties, then the compatibility tab. Try dropping the compatibility to win xp and see if that helps. If it doesn't, post your system specs and we'll work from there
Jul 25, 2010 | Take 2 Interactive Sid Meier's...
I have a 1989 chrysler conquest and dont seem to have a strong vacuum comming from the carbeurator?
Suggest lots of possibilities...I assume it is NOT a TSi... so no Turbo.
If all vacuum lines are attached and in good shape, then you can have a back pressure issue, preventing the flow of burnt gas out of the engine, and therefore a low vacuum.
If you find that the Cat. converter is clogged (strong possibility...) the you can buy one...
http://www.carpartswholesale.com/cpw/chrysler~conquest~parts.html
Chrysler Conquest Catalytic Converter inv-dots.gif Notes : UNIVERSAL, 4 Cyl, 2.6L,CENTER UNIT Part # : CPWCC-70316 OEM # : Fit : 1987-1989 Chrysler Conquest (87-89)
Nov 23, 2009 | 1989 Chrysler Conquest
Civ 3 wont run on new Netbook
maybe your system requirments are not upto the mark. check the requirments of civilization 3 and compare with your system.or the game disk may have a problem, get it replaced if you can and try again. system requirments of civ 3>>> Macintosh:
  • MacOS 8.6 or higher or MacOS 10.0.4 or higher
  • 300MHz iMac G3 or better (500MHz preferred)
  • 64M RAM for the classic MacOS (96M preferred), 128M for MacOS X.
  • 500MB Hard disk space (650MB preferred)
Aug 06, 2009 | Infogrames Civilization III: Gold for...
Can i play Civ II on my brand new mac?? or do i need an older mac
Civ II is a fairly old game. It seems that your PC runs Windows XP or earlier. It is likely that the site you read was correct, and your computer is too new to run it. However, you may be able to get another newer version of Civ for Mac, but check the system req's for any game you try to install. I don't know for sure if this is the case, but I hope this helps you somewhat.
Jun 01, 2009 | Macsoft Civilization 2 Gold for Mac
CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Apr 25, 2009 | Candy Dryers
Won't let civ 4 play
Did you download it illegally? Regardless, Norton sucks and you need to get rid of it. Most likely The firewall in Norton is blocking access from the program on your computer. Open Norton and Find the Firewall settings (i havent used norton in many years so i forgot where it is; Possibly udner configure or settings or something). Allow access to the program through the firewall and if you bought it then allow full internet access to it as well. Hope that helps :)
Apr 06, 2009 | Video Game Consoles & Games
I need an activation code for civ iii
you will need to contact the developer:
US Support
Phone: 1-866-219-9839
Email: usa@take2support.com
Mar 20, 2009 | Macsoft Civilization 3 for Mac
MacPro, Civ III Complete with Intel Update
Figured it out: http://support.aspyr.com/index.php?x=&mod_id=2&root=239&id=598
Make sure you have the 1.22 Rev A patch and then get the new fix (both links are on the page linked above).
Jan 30, 2009 | Macsoft Civilization 3 for Mac
Atari Civilization III: Conquests for Windows Logo
63 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
