Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Loud humming noise when spinning - Bosch Nexxt Premium WFMC6400UC Front Load Washer
  • Bosch Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 22, 2013
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Humming sound when Sony DVD player is turned on. The player is attached to a TV. The sound continues when a DVD movie is played.. The intensity of the humming changes with changes in the Video.
Is the humming just from the power on or is it when the DVD is spinning some media will spin with a loud humming noise something to do with the balance similar to an unbalanced car wheel, just a lot quiter. Burn the DVD using ImageBurn create an ISO and reburn.
If it hums without the DVD spinning it is probably the transformer on the PSU on it way out this can happen at any time it is caused by the voltage step down coil becoming damaged in some way and the lower voltage provided causes the noise.
If this is the case I suggest a new PSU or at least a new Transformer.
Jan 07, 2010 | Televison & Video
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Loud noise
you may have something stuck on the blower wheel
Jun 03, 2008 | Whirlpool LER3622HQ Electric Portable...
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
74 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
