What is the resolution on my direct tv receiver d12-100
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
How do you change the 480i to the 720p using the remote
That isn't how resolution works. The resolution is changed in the cable box or satellite tv receiver. The television automatically displays the resolution once it has been changed on the cable box or satellite tv receiver. If you are on input tv on the Sharp television then it will not display any other resolution besides 480i if you have a cable box or satellite tv receiver. If you are not connected to a cable box or satellite tv receiver and you are on input tv then the resolution will differ from channel to channel.
Feb 10, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
Hello, I just bought a HT-S5200 home theatre. I connected my blueray through HDMI to the AV reciever and from the AV to my screen. The problem is that I can't get a picture. If i connect the blueray to the...
Connecting directly to the TV is ideal....but then you would have to connect the audio through coax or optical unless the bluray player had an additional HDMI out.
So...what connection is going from the receiver to the television when it does not provide picture? If you do not have HDMI, DVI or component video going from the receiver back to the TV then you won't get a picture. However, you may not also get a picture if the video output resolution is adjustable in the receiver as well and does not match...make sure that the TV is set to the same resolution as the receiver, and that the video output of the player is also set the same.
Dec 19, 2009 | Onkyo TX-SR605 Receiver
No image/sound when sony ps3 is connected to onkyo 875
I've had problems with my Onkyo receiver too.
Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
hope this helps,
Aug 13, 2009 | Onkyo TX-SR875 Receiver
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
