First - Check the connections on the speaker itself - when speakers don't work. it's usually the wires from the power amp section to the speaker. If those are OK, try replacing or bypassing the headphone jack - you may have a short in the output jack.
Good Luck
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
I believe the design of this results in what you are seeing... Check each speaker INDIVIDUALLY plugged into the MAIN output as plugging into the second jack shifts the tap of the output transformer to the 4 ohm tap which results in a 6 Db drop but now you have two speakers... the apparent level change will be almost unnoticeable.. Do comparision of the speakers individually using the MAIN jack. This is just the characteristics of the beast...
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Check all the capacitors one at a time for leakage.You might also have a transistor in the preamp stage which is starting to go bad. Whatever you do though don't use the speaker output jacks of the organ as line outs into the input jack of the guitar amp. In a properly working organ you could destroy the output transformer and the input stage of your amp because most speaker outs are A.C. voltage to drive the speakers not low level D.C. which is what your amp is used to. Let me know how you make out.
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
