I have a 5 month old ge harmony front load dryer. On a few occasions during the dry cycle when the dryer changes motion, it make a brief shaking motion. It dries fine, but its new so I was wondering if there are any issues to be resolved before it gets worse
Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry
Loads dried using the Towels, Heavy Duty, Normal, Perm
Press, and Delicates cycles will dry automatically at the
selected temperature to the desired dryness level. The
dryer uses sensing bars to sense the moisture level of
the load as it tumbles through heated air. Auto Dry
cycles save time and energy and protect fabrics. The
estimated drying time will be displayed for about 5
minutes, then the outside of the display will light up in
a circular track to indicate the drying time is automatically
being determined by the sensors. When the load
has reached the selected dryness level, it will continue
to tumble, unheated, during a Cool Down period. This
helps reduce wrinkling and makes items easier to handle
during unloading. The estimated Cool Down time will be
displayed.
Drying time varies depending on size and dampness of
load and fabric type. If the load is too small or almost
dry, the sensing bars may not detect enough moisture
to continue the cycle and the cycle may end after a few
minutes. Select a Timed Dry setting to dry such loads.
Room temperature and humidity, type of installation and
electrical voltage or gas pressure can also affect drying
time.
For cycle selection turn the knob on the front of the
dryer control panel. The light will illuminate next to
the cycle selected. The following is a brief description
for what cycles should be chosen for certain items and
materials to be dried.
Check for a removable panel at the bottom, either front or back. If you can't find them, they may have landed on some part. Shake the machine as hard as you can to see if you can dislodge them. If not, turn the machine upside down and bang the sides with your open hand. If still nothing, they may be caught in the wiring and you will need to remove the drum to find them.
Wow...does it sound like it's about to take. You can hear it all over the house even with the door to the room closed? We have the same reason. THis started after a bout of lice in the house and we were doing many loads a day for a while. Help!
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
