Question about Bosch WTMC632SUS Electric Dryer
My nexxt premuim dryer wtmc632sus led screen on cotton wont read 152 anymore just 117
Screen only reads 117 on cotton and usedto read 152 on timer screen
    Genius:
  • 1,669 Answers
Timer needs to be replaced!
Posted on Jan 22, 2013
3 Suggested Answers
SOURCE: Bosch Nexxt 500 Dryer -- Permanent press cycle not
Same problem here
Posted on Oct 07, 2010
  • 3 Answers
SOURCE: dryer won't start
Had this same problem on a Nexxt 500 plus dryer. First, go outside and put up a clothes line so the wet clothes are out of the way :) LOL Anyhow to access the belt pulley fand the little switch, you have to remove the top and rear. First unplug everything. Then get a Torx T-20 driver. There are three kinds of screws so go slowly and keep them separate! Remove the top (two small screws at rear). Unplug the power cable and the ground wire. Remove most (not all!) the screws around the outer edge; several do not go thru the back panel and stay in. Finally remove all the screws in the center of the rear panel. The rear panel should left off easily. The tan box with the two thumb-tack like pins that are surrounded with springs should be easily visible at the bottom. Push the one that's out in space, away from a vertical steel piece. You should hear a little click. Reassemble (you kept the 3 kinds of screws separate, right?) and test.
Posted on Oct 09, 2011
ROPER MODEL RED4640YQ0. DRYER WILL NOT HEAT.THERMOSTATS AND HEATING ELEMENT GOOD
What I do is basically remove the drum and look for signs of lint. I clean it all up then check all the components removing a wire from each to get a good read. After you made dang sure all of them thangs have continuity you need to first make sure you have 240 volts going into the machine. The motor on dryers is 120 volt and runs on a separate circuit from the 5000 watt 240 volt heating element. So the dryer will run if the cord is bad or not connect corect OR the circuit breaker is bad OR tripped due to some sort of shorted wiring in the receptacle OR a bad receptacle. So after you know that is fine you gotta check the timer. Find the thick red wire going into the timer from the heating circuit (usually marked RH) remove it from the timer. Set the timer on a heating circuit like cotton or permapress and check between that terminal of the timer and all other terminals on the timer. If you cannot get a reading then your timer is fried inside and is in need of replacement. Google Roper dryer no heat and my video will show up. I did a couple on youtube. Estate dryer also on my youtube channel is a nice video. I have service manuals also on my youtube channel.
Sep 26, 2013 | Roper Dryers
Where do I find the reset button on my Bosch Nexxt 500 series dryer? The dryer will run, but no heat is coming out.
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Mar 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer turns on and blows, but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
PANEL DOES NOT ILLUMINATE AND NOTHING WORKS PRODUCT IS RECEIVING 240 VOLT POWER.
check the cord on the back of the dryer itself as sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced. Maybe the door switch also. Good Luck Tim
Dec 24, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
Dryer turns no heat, where is red reset button? do you have to remove the entire back of the machine?
Dec 05, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
My dryer doesnt heat or turn when start button is pushed
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
I have a toyota 2004 and the cd player wont read cd's anymore. how can i fix it? It doesn't say error; it simply won't read any type of cd.
If ur cd player wont read cd's you may try following steps:
* Clean your cd player's lenses with a cotton carefully.
* Your cd player might not be getting sufficient power.
Mar 19, 2010 | Car Audio & Video
Our dryer reads E01. I can't locate our manual so what does that mean? Thanks
E01 - lint filter dirty, exhaust air duct is blocked or too long, fault in program sequence or malfunction, the room/cabient is not adequately ventilated.
Feb 13, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch WTMC632SUS Electric Dryer Logo
47 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
