Question about Linksys Wireless-G WRT54G Router
After 30 min connected to the internet I am dropped from the internet. It says I am still connected to the Linksys router. It sems that It is timing out. What to do? Do I need to download new firmware?
  • 1 more comment
  • tomhancock Jan 28, 2009
    I have a DSL connection to the internet via earthlink and my desktop computer works this connection. I connect along with my wife and son via the Linksys router. I am fine. My computer connects well through the Linksys and I am never dropped. But for some reason my wife and son keep getting dropped the awhile. They can only reconnect after I recycle both the DSL modem and the Linksys router.
    -I am never dropped (Sony Vaio Laptop)
    -Wife is dropped after awhile (Mac Book)
    -Son is dropped after awhile (Toshiba Laptop)
    What's going-on?
    With the 3 Laptops, they are all wireless and the desktop (iMac) is connected via ethernet.
    Why would my wireless connection never drop whereas my wife and son's do? How would I fix ip address problem?
  • Dave Dieter
    Dave Dieter May 11, 2010
    what type of internet connect do you have. i am using rcn cable 1 way. which is cable in dial up out(2 seperate modems) it horrible and always disconnects especially if i have alot of download activity.
    if you show a connection to your router than the router is not the problem. if you have now internet that is a problem with your internet provider or modems. hope this helps
    Scholar:
  • 60 Answers
Check the "keep alive" settings in your router, there is usually a choice between having it constantly "pinging" to keep the connection open, or letting it disconnect when it has been idle for awhile. Make sure it is set to "keep alive". The wording may be different but it will be something along these lines. Go in your browser to the wireless router's configuration page (i.e. http://192.168.1.1 ). Depending on what brand router you have this ip address will vary, consult your documentation for which number is used.
Changing these settings may also help...  Wireless Router Configuration - Advanced Wireless Settings
Posted on Jan 28, 2009
  • 2 more comments
  • Allan Claunch
    Allan Claunch Jan 28, 2009
    I ran across someone recently having a similar problem in a network forum I belong to. It turned out with them their ISP was using same ip address subnet on their side as the user was on their side ( i.e. both were using 192.168.200.X ) which was causing similar problem, his pc never dropping out but several of the macs were. You haven't described each connection, are they all wireless, wired, mixture?
  • Allan Claunch
    His explanation on his scenario was... the routing tables were getting confused because there was an ip address conflict. I don't know what type of scenario you have and this is unlikely the case, it was just a shot. If you have your wireless router set to DHCP (serve out ip addresses as needed) and you have your computers set to DHCP (asks to be assigned an ip address) then you would not have an address conflict. If you have static numbers assigned then this could be the problem if you had the same number assigned twice. You haven't mentioned your particular model of wireless router, there are certainly some firmware versions buggier than others which would cause this but since you have one always staying connected it seems unlikely and upgrading firmware right now would just add another variable into the troubleshooting mix. Does the wired one always stay connected as well as your wireless?
  • Allan Claunch
    Some possible things to try:
    1. If you are using DHCP in your wireless router make sure the "Maximum Number of DHCP Users:" is set to at least 4 preferably higher (sometimes IPs take awhile to be freed back up into the pool).
    2. If you are using DHCP set the "Client Lease Time:" to 0 minutes (means one day).
    3. See if perhaps the energy settings on the problematic machines are set where they sleep or hibernate after 30 minutes, try turning this off to see if it corrects.
    4. What is the exact model of your wireless router?
  • Allan Claunch
    I also forgot to ask if perhaps your wireless computer is closer than your other family members, if they all have good signal strength.
Had problems changing router settings/setting up security info
in your internet browser type the address
198.162.1.1
that will take you to the setup page for your router.
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
Windows Vista Internet Connection problem
Are you on the wireless internet or on the internet through a cat5 cable? If on through the wireless I think its a wouter issue. try upgrading the firmware of your router first. If that doesn't work try using a different router. Also try upgrading your drivers on your computer for however you are connecting to the internet. Either your network card or your wireless card via device manager.One of those solutions should solve the problem.
Sep 12, 2009 | Computers & Internet
WRT150N Linksys router disables internet?
Please try the following:
1. Download the latest firmware for your router from linksys website, with the direct connection.
2. Connect the computer back to router, upgrade the firmware.
3. Then powercycle modem, router and check internet connectivity.
The above steps should help. If not, please let me know.
Mar 31, 2009 | Linksys Wireless-N WRT150N Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Internet keeps dropping out using this router
One simple solution, can you try using the router on another ISP connection (at your friends' place possibly?) This will rule out the possiblility of your ISP fault saving you $65 straightaway...
Dec 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
200 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
