Calcomp techjet720 stuck in MANUAL
My calcomp techjet720 plotter turns on, but then won't shift to ONLINE, it is stuck in MANUAL.
  • 3 more comments
  • sunteriorfla Jan 30, 2009
    calcomp techjet720 stuck in MANUAL
    I unplugged the power cord, left it for 9 hours, plugged it back in. It is still stuck in MANUAL.
    So, I do not accept the 1st solution.
    I cleaned the rod, and the print head on the ink cartridge. The plotter still reads: MANUAL [please install print head] The print head is on the ink jet cartridge, correct?
    the control panel has 6 buttons. None are stuck.
    Sorry to tell ya, I tried all your solutions with no luck.
    I replaced the ink jet cartridge, and it works.
    Your many solutions did not fix the problem.
    I changed the ink jet cartridge, now it prints.
    THIS REPAIR PROBLEM IS NOW CLOSED!
    Scholar:
  • 118 Answers
You need to go to your "start menu" and select "printers and faxes". Once you're there you will see maybe 1 or more printers. Look for yours which is the CalComp Techjet720 and right-click it to select "set as default printer". If you don't have that option then it already is and should have a check by it. After that right-click it again and make sure it is on "resume". Because it may be paused.
Posted on Jan 30, 2009
    Genius:
  • 1,913 Answers
Your printer parts need some servicindg.u need to clean all parts with iso propile remove lall blur and dustfrom it.
    President:
  • 2,559 Answers
Hi,Can you give me some details on your OS and what programs you have running the 720?
We had the same problem when we tried running AutoCad2000
It sounds like it may be just a driver issue.
  • 116 Answers
Your printer ink catridge should be changed every 2 months
    Genius:
  • 2,035 Answers
If the printhead is on cart and your getting error message to install print head then try to clean the print head and install and if get the same error then you may need to change the print on the printer ...please follow these steps :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
  • Anand Kumar
    Anand Kumar Jan 30, 2009
    Its working , that's great ...
    Good luck....
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If the p0lotter will not go ONLINE, might it be that it can not sense the computer it is attached to? If this hold true, then the issue might be how it is connected to the computer or if the port in the computer is enabled. Pls check port settings in printer properties.
Good luck and thank you for using FixYa.
    President:
  • 1,990 Answers
Http://list.driverguide.com/list/company186/page2/index.html Check here for the Drivers for your Printer. It seems that you need a New Driver to Fix this Problem. Let me know if this DoePlease Rate my Solution, I need all the Help that I can Get! Thanks!s not Work.
    Sergeant:
  • 378 Answers
Check out if any button is stuck up inside.or the sensor controlling the pannel is moved from its position.otherwise it can be the internal control pannel circuit problem.
Posted on Jan 29, 2009
  • 679 Answers
Clean the printer rod and head and check again.
let me know if it works.
  • rockfixya
    rockfixya Jan 30, 2009
    please tell me is there any error message?
    Thanks
    Sergeant:
  • 250 Answers
Remove the power plug from the back of the printer for a while then reinsert it and check.it will reset
My 03 mustang won't down shift after shifting the
HI,
Search online..but it sounds like the 'synchros' in the transmission are going/gone.
Also, the clutch may be wearing out.
Td
Oct 01, 2012 | Cars & Trucks
Yz80 yamaha motorcycle is stuck in second gear
Hi, Tnyvillalobo and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won shift stuck in one of the upper gears
My Motorcycle can shift up or down anymore Is the problem bent shift lever
YAMAHA YZ85 LC Owner Service Manual
OEM parts for Yamaha
YAMAHA YZ85 Owner Manual
Aug 02, 2012 | Yamaha Motorcycles
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
2005 Yamaha YZ85 stuck in fourth gear
Hi, Harjitbasi08 and the usual suspects are:
How to get YOUR Motorcycle out of Stuck Gear
YAMAHA YZ85 Owner Service Manual
Yamaha YZ85G Owner Manual
Jul 12, 2011 | 2005 Yamaha yZ 85
I have a cal comp a 300 phone. It did not come with instructions I don't have any luck finding it online. What can I do?
Hi - I believe this Cricket phone is exactly the same phone as your Calcomp A300.
Take a look at the manual HERE.
Good luck and thanks for using Fix Ya.
Mikeywaf
Mar 28, 2011 | Lands Phones
We have a Calcomp Techjet 5424 printer. We got it
I have the same plotter and use canon BC-02 cartridges they work fine although they can be difficult to find, have you tried refilling the empty cartridge yourself it's easy piezy.
Aug 27, 2009 | GTCO CalComp TechJET 5536GA InkJet Printer
Calcomp Drawing Board III
If you need documentation, go to GTCOCalcomp.com and they have FREE documentation for your tablet.
It may be a software switch is turned on and is causing this problem. Also check the driver and turn off any mapping.
When you read the manual it will show you how to turn off/on the software switches on the tablet.
These tablets should boot-up in the GTCO binary mode.
Feb 14, 2008 | GTCO CalComp Drawing Board III 34480...
49 people viewed this question
jasbo
jasbo
