Question about Kenmore 56722 / 56724 / 56726 / 56729
Proline plc218w not freezing
Hi my freezer has stoped working, it is showing the orange and green light ..please help...thanks
  • montwain Dec 30, 2008
    Trying to sort my mums freezer now, same model and problem, have you had any luck?
  • barbs4582 Sep 28, 2009
    PROLINE freezer door left open overnight freezer will no longer reach oprating temprature any answers welcome
  • 147 Answers
Try unplugging for 10 Mins and then Plug it Back in see if That works Tech
Posted on Jul 20, 2007
SOURCE:
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
Hi I have a upright 'Proline' freeze which seams to be running all the time and during the last few days the temp gage has moved in to the green area. I turned on the rapid freeze light and it has taken...
The fridge has lost it's refrigerant charge. The leak needs to be found and repared before new gas can be added.
A tecnician can help you with that
Mar 25, 2011 | Refrigerators
Red warning light on only just noticed it unsure how long been like it freezer is a proline chest freezer code plc218w
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | Refrigerators
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Kenmore 56722 / 56724 / 56726 / 56729 Logo
357 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
