Question about Samsung WF337AA Front Load Washer
Bra stuck in lint trap housing on samsung front load dryer
Got a piece of clothing sucked into lint trap i forgot the screen was out of the hole shut dryer and it sucked it inside and began making a screeching sound as if stuck on a belt maybe help
  • Samsung Master
  • 17,129 Answers
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Posted on Jan 22, 2013
3 Suggested Answers
  • 59 Answers
SOURCE: need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Posted on Apr 29, 2009
supernova278
  • 1932 Answers
SOURCE: Hi my Samsung front loading
This is not SE error.It is 5E error.
This is a water drain error.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
The sound may be caused due to some obstacles in the drain pump impeller.You need to remove the pump and check fully.
Thank You
Posted on Nov 16, 2010
2010 bosch vision clothes dryer overheats now it wont start
Clothes dryers have many thermostats and a fuse of r two to prevent fires when they overheat.
Probably yours is overheating from lint accumulation.
Although you have a lint screen, that screen will only get some of the lint, some will remain trapped inside.
You must take your machine all apart in little pieces to clean it completely out.
I have found up to a whole shoe-box-full of lint in modern machines.
The shutting off is because a thermostat or fuse has "popped" and must be replaced.
You can find out which one with an electrical tester.
Modern machines have a fuse or two, and up to 6 thermostats.
God bless your efforts.
Jun 30, 2016 | Bosch Dryers
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
I clean my lint trap from the dryer after every use, but i still get lint particles on all my clothes when I take them out! Its been happening every time and when i clean the lint trap its full. How do I...
Hi and welcome to fixya,
This problem can be caused by poor air circulation inside. In order to efficiently remove lint from clothes, load the dryer 1/2 of its drum capacity. It also helps putting fabric conditioner sheets to prevent clothes from charging static electricity which can attract lint..
Hope this helps,
levibit
Jan 05, 2011 | Whirlpool Clothes Dryer Lint Screen Left...
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Oct 13, 2009 | Samsung Dryers
Dryer flow sensor shows 4 bars
lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
May 08, 2009 | LG DLE5955 Dryer
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
Maytag Gas Dryer - Shuts off before clothes are dry - was cleaned ?
check to make sure no "dust bunnies" got inside you vent hose blocking air flow.
Oct 30, 2008 | Whirlpool LER4634J Electric Dryer
Samsung WF337AA Front Load Washer Logo
428 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
