Question about Husky Nailer. 3-1/2 in. Full Head Framing Nailer HFR2190
I need to replace the trigger valve, but I'm having a problem finding one.
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
DeWalt D51823 nailer shoots continusously when plugged into air hoswe
Shooting continusously caused by worn orings in the trigger valve and in the gun.Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer (white plastic). Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. The trigger valve also has vinyl orings on the trigger pin. You could try replacing the orings but hard to find . Pin uses 2mm x 1.5mm. The orings on the inner valve should fit snuggly on the outer contact surface. If the valve just falls out the the body, the orings are too loose or the body is worn. I would just replace the trigger valve to be safe, however repaired works ok if you can find the orings. Trigger orings do not come in the kit. I would also remove the nails after each use and only reinstall them after air is connected and gun seems to work as it should. The Good luck with your repair.
Dec 23, 2012 | Air Tools & Compressors
Hey, I'm having trouble with my Dewalt 18ga Brad Nailer trigger. Can you send me the directions you have on how to get into this thing? I'd really appreciate it.
For removal of dewalt D51238k trigger valve. Remove the nails.
Remove the pin holding the trigger in place. Then remove two roll pins in the body of the gun just above the trigger (3mm roll pins). With gloved hand, apply air pressure to the gun which will pop out the trigger valve. Use caution because the valve could come out with force. Try with low pessure first, then increase as needed. If you are removing the trigger because the gun will not fire, (only puff of air from trigger area), suspect problem in the head valve instead (usually, trigger valve is bad if air leaks from trigger when you connect air ). Good luck
Sep 26, 2011 | DEWALT D512381 18Gauge Brad Nailer ORing...
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Air leaking around trigger valve. Air blowing out of green valve center pin gets push in in nounal working condition but now air blows out continue when hooked to air pressure
there is an oring that has split on the trigger valve and you would need to replace the valve assembly. Without knowing which tool you have I can't give you a part number but if you look in the tip section I have detailed instructions on how to remove and replace this valve. If you give me the model I will try and find you a source and part number for your nailer. Let me know if I can be of more help or if you have trouble finding the instructions.
Jul 04, 2011 | Stanley Bostitch Nail Gun
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
How do I fix air coming out of the trigger? and can I take it apart and fix it my self. Will it tell me in the mannual? but I don have it.
you can fix yourself if you have a small pin punch. You will need to get a new trigger assembly, the o ring in the valve has split in half. To replace and follow closely, first disconnect air line, take the pin punch and drive out the pin holding the trigger itself and then drive out the pins holding the trigger valve in place. Now and do exactly as written, find a shop rag or cloth put under the trigger valve and hold it. While holding the collar back on the quick disconnect push the air supply onto the fitting and the valve will "pop" out. when replacing the valve use a light coat of grease and align the slots in valve with the holes where the roll pins go, reinsert and you should be ready to go.
Nov 09, 2010 | Stanley Bostitch F21PL Nailer
NV65ah Hitachi nail gun "how do you remove the trigger piston"??
If you do not have a breakdown of the gun go here www.toolpartsdirect.com and select brand, then select coil nailer, finally look for your model number. With breakdown, find parts labeled 51 thru 54. The trigger pin (#53) and the retaining ring (#21) hold the trigger. Remove these then remove the trigger. Find several #51 roll pins on the gun and punch out the uppermost pin where the trigger valve is located (3mm size). The uppermost rollpin holds the trigger valve in-place. After you have removed the rollpin/s connect air supply to pop-out the trigger valve. Caution, use a heavy glove (or reduce pressure) to catch valve as it can come out with force. When incerting the rebuilt valve, use caution not to cut new orings as the valve is pushed in. Good luck and email if you have more questions.
Mar 15, 2009 | Hitachi NV65AH Siding Nailer, Coil,...
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Husky Nailer. 3-1/2 in. Full Head Framing Nailer HFR2190 Logo
48 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
