Question about BBE 382isw 2-channel Sonic Maximizer W/subwoofer Control 382i Sw
How to hook up mixer maximizer and subwoofer - BBE 382isw 2-channel Sonic Maximizer W/subwoofer Control 382i Sw
Just bought a Mackie profx16 with two speakers and a Mackie srm1801 subwoofer. how do I hook them up together?
If you bought it short ago and can return it, i would do it, and buy a better mackie mixer without the bad soundinding dsp on it. But you have to buy another cable or just a direct plug on connector
Oct 07, 2014 | Audio Players & Recorders
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
I have a 1002fx mixer how do I connect it to my maximizer
Normally output to maximizer first then from there to crossover.
Dec 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I need to know how to connect a powered subwoofer to my pv10
The most functional way to use a powered subwoofer with this mixer would be to plug it into the EFX Send output. Then you can add whichever channels you want to go to the subwoofer (i.e. YES for the iPod, NO for the mics) and how much by using the EFX knobs for each channel. Note that when you say "powered subwoofer," this assumes you mean "self-powered subwoofer," because this mixer will not provide power.
Oct 10, 2013 | Peavey PV10 USB Mixer
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
Can I hook up 2 separate power amps to PMP3000? I
Better way... Connect the main speakers via the Speakons and then put a Power Subwoofer to one of the Monitor connections IF you are not using both stage monitors. If you need to kill the lows to the mains, use the EQ in the PMP-3000.
Use the EQ that is USUALLY on the subwoofer to kill the highs to the sub.
Lot less cables and hardware.
REMEMBER for equipment safety, power ALL interconnected equipment from the same source be it a receptacle or power distribution system.
Powering parts of a system from receptacles strewn around a room is asking for trouble of ground loops and ground faults.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
BBE 382isw 2-channel Sonic Maximizer W/subwoofer Control 382i Sw Logo
52 people viewed this question
Top BBE Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a BBE Audio Player and Recorder Expert? Answer questions, earn points and help others
