Question about Frigidaire Washing Machines
Frigidaire Affinity washer was giving an error code of E20. We followed the recommendation of other users, and cleaned out the filter where the water drains out. We tilted the machine on it's sid
  • Frigidaire Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 22, 2013
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
RixsFixes
  • 2200 Answers
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
  • 193 Answers
SOURCE: error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Posted on Oct 30, 2009
  • 662 Answers
SOURCE: Frigidaire Affinity E20 code without washer draining?
Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
You can give me a very helpful rating for the free help, can't you. Thanks.
Posted on Jun 13, 2010
  • 2468 Answers
SOURCE: how to clean a affinity frigidaire front load
remove the toe kick panel just below the front door and its located right below the drum
Posted on Oct 01, 2010
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
Code E20
Oct 12, 2012 | Frigidaire Affinity ATF6000F Front Load...
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Jun 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
