Question about 3M Samsung BD-D5100 Blu-ray Player
Gateway ping on Samsung bd-d5100
Why am I getting gateway ping error message
What is Gateway Ping
Ping is used to check for a network path to a specific host. In this case the script will ping from domain.com to the host you provide. Ping should be the first TCP/IP diagnostic tool you use when tracking down a network problem. Ping uses a series of Internet Control Message Protocol (ICMP, often-pronounced eye-comp) messages, that produces an Echo message to which every host responds. When Ping uses the ICMP messages and replies, it can determine whether the other system is alive, and also compute the round-trip delay in communicating with that system. So Ping can show you how fast the connection is between two ip addresses or domains.
Oct 11, 2011 | Samsung LA40A550 40 in. HD-Ready LCD TV
Operating system: Windows XP Home Edition Model: Acer One Aspire Problem: PC sees wireless networks & connects but Internet Explorer &/or Mozilla don't get me on the internet.
please ping your router gateway,for seeing default gateway you take command prompt and type ipconfig, there you can see your default gateway then type ping gatewayip (eg: ping 192.168.0.1) if you are getting reply from that gateway your computer communicating with your router.If you are getting request timedout then there is a problen in communication.If you are getting the reply then you just ping google (ping www.google.com).getting reply the connection to the internet is fine.If not there is problen in internet connection in the router.
Jul 21, 2011 | Computers & Internet
I purchase a netgear universal wireless internet adapter to connect on my samsung tv to get the internet , netflik etc.....i was not able to pass the test with the gateway ping which failed. the model...
I have a couple of questions
1. What gateway are you pinging?
2. From what device are you sending the ping?
If you are trying to ping the gateway on the modem/router provided by your internet service provider then you will not get a ping response, this is because it's configured not to respond.
Oct 06, 2017 | Computers & Internet
Samsung BD 6300 blue ray player does not connect to wireless access point. Gateway ping seems to be the issue, current gateway is on the network. Using my landlords router with his permission. Suggestions...
I'm not sure if I'm reading this right but, Is the Access Point in your apt? Or are you trying to access his router directly with your 'Player?
If you are trying to connect to an actual Access Point, try connecting to the AP from your computer either wireless or via the Ethernet cable and set it up to access his router/internet. When you can surf the Web or access his network on the computer using the AP then unplug the cable if you used it and just go into the Samsung's network settings and try again.
The only other thing I can think of is make sure his router is set to MIX, b/g/n speeds.
Jan 04, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I am trying to hook up a Samsung WIS09ABGN LinkStick Wireless USB 2.0 Adapter to a Samsung BD-C5500 Blu-ray DVD player. In going through the setup process after I set up the router connection which...
To resolve issues with the Internet Gateway connecting to the MyQ server
1. Determine if you can connect to the Internet using your computer. If you cannot connect, proceed to step 2.
2. Reset the router. Unplug the router for 30 seconds and plug back in. It can take a few minutes to reconnect to the internet. If you still cannot connect to the internet, contact your Internet Service Provider before proceeding.
3. Move the Internet Gateway ethernet cable to another port on the router. Put it in one of the ports on either side of the current position on router. Make sure that the Internet Gateway is plugged into a LAN port, normally numbered 1-4. Proceed to step 4 if none of the ports work.
4. If you are using a modem and a router, disconnect from the router and plug the Internet Gateway directly into a LAN port in the modem to bypass the router. Note: This will turn off the internet to the rest of your home network temporarily. If this works:
5. If step 4 doesn't work, power cycle your home's internet modem, it may need to be restarted to provide a new IP address to your network.
6. Perform a Soft Reset on the Internet Gateway. This renews the IP address with the router. The LED lights will blink like a normal power up. To perform a soft reset:
1. With a safety pin or paper clip, press and hold reset button while the Internet Gateway is still plugged in.
Note: The reset button is located on the side of the Internet Gateway in a recessed hole.
2. Hold the button in until you see a yellow LED light blink and release.7. Perform a hard reset on the gateway. This deletes all the devices and renews the IP address with the router.
1. Unplug the AC adapter from the gateway.
2. With a safety pin or paper clip, press and hold the reset button on the side of the gateway.
3. Plug the AC adapter back in while continuing to hold down the reset button until the yellow LED light blinks.
Dec 08, 2017 | Samsung WIS09ABGN (8808993304486)...
My computer will not boot (gateway LX6810-01). I
What did you use to make the CDs and what error messages or deviant behavior are you seeing? Nero Wayback? If they're not bootable, boot the relevant software recovery system and set that to use the CDs.
If it's not booting from any bootable CD because the BIOS settings prevent that, go into the BIOS and permit booting from optical drives (CD/DVD/BD) or reset the BIOS then go in and set things properly.
Feb 13, 2010 | Gateway LX6810-01 PC Desktop
I have the Samsung BD 3600 and the Belkin N router and fail the gateway ping. Help
if you are trying to ping the router from the outside internet, the ping function is probably shut off. If you are trying to ping the router from a local pc either the pc is not connected to the router network or the router network is not the same as the pc network (example: router gateway ip is 192.168.55.1 and your pc is looking for 192.168.1.1. Check the router gateway id. If you can get to the router, you are probably ok.
Send more info if you can't resolve the issue.
Jan 30, 2010 | Belkin Computers & Internet
Dynex router blocks connection of Samsung BD-P1600 Blu-Ray to Net
I'm not familiar with that particular router, but all of them are about the same. You can go in and edit firewall settings to allow a particular IP address to have access. Don't disable the firewall completely, just set it to allow that I.P address to have full access.
Nov 15, 2009 | Dynex 4-Port Ethernet Broadband Router...
My blu ray cant ping my gateway. i have a bd-1600 and it wont connect to netflix
Try shutting down your firewall on the router itself. Routers will block ping request and therefore won't let it connect.
Nov 14, 2009 | Computers & Internet
Samsung BD P3600, can not connect to the Wi Fi system on my Apple Time capsule. IP address I have Subnet mask number I have gateway number I don't know what this means DNS server number? I hope someone can...
Forgive me if you know this already IP address needs to be different to the Apple one. If the Apple one is 192.168.0.1 make the Samsung 192.168.0.2. subnet 255.255.255.0. Gateway should be the same as the apple number.. DNS can be left to automatic but if stuck use 4.2.2.3. Check the security settings on both the Apple and the Samsung are set to the same type
Oct 11, 2009 | Samsung BD-P3600 Blu-Ray Player
3M Samsung BD-D5100 Blu-ray Player Logo
112 people viewed this question
Top 3M Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a 3M Audio Player and Recorder Expert? Answer questions, earn points and help others
