Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
My Fisher Paykel washing machine works well but seems to need two spins to dry properly all of a sudden, blocked pump?
When I go to empty the washer at end of cycle clothes are still quite wet and so have to spin dry at least one more time. Is this likely to be a blocked pump?
  • Fisher and P... Master
  • 17,130 Answers
It can be due to insufficient RPM of the dryer or due to water logging within the drum.
Please check this link for tips:Pump
Check the drive for jamming of the spindle.
Posted on Jan 22, 2013
4 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 713 Answers
SOURCE: fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: My washing machine will not spin out Clothers
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 22, 2010
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Rinse and spin cycle not working
sounds like a blocked pump. unplug, empty as much water as poss, lean backwards against a wall. remove pump (front right, turn left, has a little plastic lock you will need to push away) remove blockage. restart machine. it is possible that the pump is overheating, if you find nothing inside the pump cavity, you should look out next time you pump, and check the pump for overheating (CAUTION pump may be HOT!!)
Sep 13, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Hi there, my washing machine will not spin dry and the machine wont empty, i have tryed turning it off at the wall and nothing! please help
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 30, 2011 | Fisher and Paykel IWL12 Top Load Washer
My Model GW712 won't spin or drain Top loader fisher & paykel
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fault 37 but pump is clear and does work part of cycle
there is a blocked pressure chamber or switch remove and clean then try again / it is letting to much water in
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL10 US won't spin
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
32 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
