Question about LG 42LB5D 42 in. LCD Television
Power Supply problem
I have a LG42LB5D that will not power on. The stand by light doesnt even come on when it is plugged in. I have removed the power board and dont see any visibly apparent defects or blown components. I have a multimeter and am sure that power is getting to the board. can someone advise me on how to further test this board to see if i need to replace it? It would be great if its just one of the capacitors or something, but i cant seem to locate a bad one. please help.
  • 211 Answers
SOURCE: Stand Removal
Hi Trevor,
I haven't looked at the 47LG6000 yet, but I'll think that there are 4 screws on the back that you have to unscrew to release the socket. It may be taht there's also a clip that you have to push.
Regards, Gerard
Posted on Oct 23, 2008
sure_thing
  • 157 Answers
SOURCE: How do you find out which capacitor is bad on
Usually you can identify defective capacitor when you see the the top cover on it pop up, sometimes short circuit across its terminal can be checked by an ohm meter. Hope it helps
Posted on Mar 11, 2010
Testimonial: "Thanks! That helps alot."
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
SuperTech-11
  • 1591 Answers
SOURCE: Failed Repair Job. A friend of mine called a
replacing the 10V caps with 25V caps is perfectly fine. In fact, if it was manufactured like that, those caps may not have blown.
Replacing a 680uF with a 1000uF could be problematic depending on it's function.
680uF is pretty specific when 500uF and 1000uF are much more common and therefore cheaper - one would think that the engineers would have tried using those in the design rather than a 680uF - makes me think the value of the cap is important to the frequency of the circuit it's in.
Other concerns might be whether he got any of them in backwards or not.
That's a rookie mistake, but still an easy enough one to make (for a rookie).
Also, with that many swollen caps, I wonder if there were any that leaked out the bottom before swelling at the top (IE - if some caps were missed in the replacement procedure)
Also, with that large a number of caps gone, other components may have been compromised or blown.
I'd be testing the transistors around those caps (most likely punched through rather than open), looking for fusible links (surface mount fuses, 0 OHM resistors) that may have opened up etc.
The initial attack on the problem was basically correct, and in many cases probably would have fixed it (if say the 680uF cap was functioning as a ripple filter).
But when that didn't fix it, a deeper analysis should have been done to complete the repair (including locating a 680uF cap).
Posted on Feb 27, 2011
Testimonial: "Excellent and through description of recommendations."
ankitchandel
  • 141 Answers
SOURCE: Have a 42PC3D-UD plasma tv.
Go to nearest help centre and check your tv
Posted on Mar 24, 2011
Lg42lb5d sound no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
May 09, 2016 | LG Televison & Video
Emerson lcd no power
There could be power supply problems even though there is no visible evidence.
Dec 01, 2013 | Emerson LC501EM3 50" 1080p 60Hz Class LCD...
I have a 32inch vizio tv that has no orange light on the logo but when turned on there is a white light and no picture or sound can any one help
The power supply board has some issues with its stand by supplies which should turn the logo orange as soon as its plugged in if the logo doesnt turn orange replace the power supply board You can get the power supply board from www.tvrepairworld.com
Dec 13, 2012 | Televison & Video
A friend gove me her lg plasma and ive plugged everything in and it hasnt even got a stand by light it has no remote
When no standby light the unit has a problem in the power supply circuit, you may need to first check the line fusee on the power supply to make sure its not blown. If the fuse is good then you may need to futher troubleshoot the power supply. All televisions have standby lights you just may not be visible because of a falty 5 volt stanby voltage..
Aug 03, 2011 | Televison & Video
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
HP Pavillion dv9000 - won't power up The kight on the power plug is on but nothing. HELP
there can be various reasons for ur question.. first.. try to remove the power supply cord of ur computer and press on the Power On button for a duration of atleast 5 - 6 secs.. i.e., even after removing the power supply cord.. and then try to boot ur computer.. let me know even if this doesnt works out for u .. regards, Guru
May 03, 2010 | HP Computers & Internet
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
My acer doesnt power on at all i plugged it in to the charger and it wont charge power light doesnt even light up and i plugged it in with no battery and still nothing. any ideas on whats wrong with it?...
Check it by putting it on another Power Adapter. It sounds to me as if the Power Supply has failed... Thats the bit that supplies DC.. to the laptop, and charges the battery, they fail frequently. Take it to a PC store and ask them to test it with another supply. The Power Supply MUST be the same specs tho.
Jan 19, 2010 | Acer Extensa Laptop
Emachine t5026 does not appear to have any power, when you unplug the power cable from unit the ehaust fans breifly turn on, and light on mother board flickers, other than that sign of power Tried putting...
Unplug every thing such as the CD/DVD trays, Hard Drive, take out any dial-up modems, network cards, video cards, etc. unplug even the mouse and keyboard. Try powering on agan. If the computer seems to work, then power back off and plug in one device then power on computer. Keep doing that until you find the bad device preventing the computer from turning on.
If that doesnt work then carefully remove the RAM completely then carefully replace the RAM. Now with on the Dynex power supply plugged in to the motherboard, try again. If still nothing, remove the RAM and try again. If it still does the same thing, then the motherboard is dead and needs replaced. If instead you get a series of beeps then the problem MAY be bad RAM. Try different RAM. If that doesnt help. The only thing left is taking out the CMOS battery, It is the coin shaped battery on the motherboard. Take it out and wait 20 seconds then put it back. I doubt it is the CMOS battery, but at this point it is worth a shot.
Nov 13, 2009 | E-Machines T5026 PC Desktop
LG 42LB5D 42 in. LCD Television Logo
46 people viewed this question
Computer Repairing
Computer Repairing
