Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
My Martin Ventless Infrared Heater won't stay lit. what do i do?
The pilot will lite, then when you turn it on, it will go out after a couple of minutes. Sometime the pilot will go off and will not re-light until it has cooled. what is wrong?
Therinnaiguy
  • 1420 Answers
SOURCE: gas heater
Mae, It sounds like you may need a new thermocouple and maybe your pilot needs cleaning. If you are mechanically inclined, you can remove the old thermocouple and take it to Home Depot or Lowe's an they can fit it to a new one. To clean the pilot, you will need a can of air used for electronic equipment. Remove the pilot assembly and shoot a stream of air through where the gas line was hooked to it. This will dislodge any debris caught in the orifice. Do not shoot the air from the pointed end as it will blow out the pilot orifice and you will never find it. Using a soft wire brush or stiff tooth brush, scrub all other pilot components and make sure there is no carbon build up an anything.
Hope this helps!
Posted on Nov 05, 2007
Buffalo12980
  • 625 Answers
SOURCE: wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Posted on Nov 16, 2007
  • 193 Answers
SOURCE: INFRARED HEATER WILL NOT STAY ON. PILOT KEEPS GOING OUT AND UNIT
You need to blow out lint in pilot assembly or replace the pilots
Posted on Sep 29, 2009
SOURCE: My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Posted on Nov 22, 2009
SOURCE: Rinnai Tropic ventless heater. Pilot will light
found that the pilot tube had dust bunnys in mine so blew it out with a air can i had for the computer now the pilot light stays on just fine
Posted on Feb 09, 2010
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Glo warm ventless heater will not stay lit more than a few seconds burner not pilot lite
this happens yearly..usually it is the thermos couple needs cleaning..this year the pilot orfice itself was dirty and throwing a weak orange flame that was not even touching the thermo couple..I just gave the orfice a good cleaning and now the flame reached out as a long BLUE flame touching the thermo couple and it stayed lit on the first try
Dec 02, 2010 | Desa International Blower Glow Warm Wall...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace heater and can't get the pilot light to light. In the past, I've had problems keeping it lit, so I've kept pilot lit all year. The other day I successfully used...
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Dec 12, 2009 | Desa International Unvented Gas Space...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
237 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
