Question about Bosch Dishwashers
My dishwasher will not start. The cecle time just keeps flashing, and the start button won't turn the cycle on. There is no error code, and the door appears closed properly
Smu50e35au
  • 1 more comment
  • amelia Jan 22, 2013
    Fgainer - which fuse do you mean? No problems with any of your other suggestions. It did a similar thing 3 days ago, and we got it working somehow - (fiddled with lots of things, not sure which was the magic trick). THen the next time we go to use it same thing, but cannot get it to stop flashing. Wakillerbee held the start button for 2 minutes, didn't stop flashing.
    It's only 6 months old.
    I fixed it. I think it was overloaded so wouldn't start.
5 Suggested Answers
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Flashing six setting modes and won't turn off.
DONOT START MACHIN BUT BECOM FULL WATER AND ERROR OE
Apr 04, 2013 | Dishwashers
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Dishwashers Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
