Question about Boston Acoustics CS26 Speaker
Boston Acoustics CS26 Speakers sound cuts out for over a second at higher volumes tested using two different amplifiers same problem. Does not seem to be related to amp distortion:clipping protectio
Have taken the speakers with the amplifiers (NAD 35 watt and Arcam Delta 290 75 watt) back to the shop they were sold by but could not replicate the fault !! Only different was speaker placement and power supply. Back home same problem every time. Spoke to Boston acoustics who tried to be helpful but do not have a solution. As I do not have the receipt I cannot get them checked/fixed under warranty.
    Genius:
  • 1,669 Answers
It sounds like the speaker cones(if that is what they have) get hung up against the back of the case. No vibration=no sound. Check to see that there is no hum adding to the pressure on the speakers. Check to see that the speakers are hooked to the correct impedence output of the amplifier. Also, wire length affects impedence and shortening the wires might help.
Posted on Jan 22, 2013
  • 1 more comment
  • John Foley Jan 22, 2013
    Hi thanks for your input. Checked the position of the cone when sound cuts out and the cones are momentarily right at the back of their movement. If the cones are getting hung up against the the back of the case what is the solution? New info this issue only happens when the speakers have warmed up i.e. not from cold, which explains why it did not do it in the shop.
    UpUpdate (2) sound cuts out only when both speakers are connected to amplifier/s
  • Leigh Perlmutter
    Leigh Perlmutter Jan 22, 2013
    The cones may be stretched out, too soft for the power of the amps>
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
Where can i find replacement wires?
I hope that helps.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
All static from the sound bar. adjustments don't help. tried different cables - that didn't help. System is not usable at this time.
The manual...
http://www.retrevo.com/search?q=Boston+Acoustics+TVee+Model+Two
Page 7
Distorted sound from the Soundbar.
Change the Trim Level switch setting to a higher number.
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The woofer seems to have interference with its wireless signal.
Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
Feb 08, 2011 | Boston Acoustics TVee Model Two TV...
My Boston Digital BA735 speakers are not working. power is on. cords are correctly placed, volume on comp is not muted
Try to isolate the problem. Connect the speakers to another computer or mp3 player or stereo. Test the speakers for sound making sure all volume switches are on. If they work look to sound settings on your computer.
Oct 04, 2010 | Boston Acoustics BA735 Computer Speakers
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
BOSTON ACOUSTICS BA735 volume is LOWER than MAXIMUM LEVEL
OK, a few things here. First of all, what program are you using to listen to music? Some programs have an automatic volume leveling setting. If you're using Windows Media Player, it has one. Next, you should NEVER set any speaker/volume/amplifier knob to Maximum setting if you want to get any life out of your speakers. Speaker ratings are for consistent volume levels at a "clean" power level. When you turn any music source up past 80% you are pushing more distortion through the speakers that they cannot reproduce without self destructing. The human ear cannot hear this, and the volume gain is minimal. Next we'll talk about that your dealing with a combination of power levels compiling into an amplifier that may be taking in more than it can aptly amplify according to it's power multiplier scheme to increase the volume at the speaker level. If you've got everything maxed out, you're probably just pushing it all WAY too hard. All over exerted energy that is not being used productively will end up in generating heat and distortion. Those are your 2 biggest enemies when it comes to anything audio. Distortion tears voice coils and generates disruptive electrical currents, and heat destroys circuitry and components in amplifiers. The times where they jump up in volume, just look at that as borrowed time until they blow. If you want louder, get a better or more powerfully rated set, and still, NEVER turn it up past 80% if you want it to last.
Jun 09, 2009 | Boston Acoustics BA735 Computer Speakers
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Feb 18, 2008 | Boston Acoustics BA7500 Computer Speakers
Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
Oct 25, 2006 | Boston Acoustics BA7500 Computer Speakers
Boston Acoustics CS26 Speaker Logo
144 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
