Question about Whirlpool Home
Lasco Whirlpool tub manual - Whirlpool Home
3 Suggested Answers
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
PartsCenter
  • 125 Answers
SOURCE: My lasco whirlpool tub leaks scum from the jets do
you need to use a cleaning solution to get the bacteria out of the plumbing lines. suggestions: Jet Cleaner
Posted on Nov 15, 2009
My jets are humming In the lasco luxury bathware how do I fix
The humming suggests that the pump is running but something is clogging it. You will have get access to the pump and probably do some disassembly to isolate the cause and correct it.
Jan 26, 2015 | Home
Lasco bubbler massage tub
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
Feb 02, 2014 | Jacuzzi Nova Whirlpool Tub H532
I have a Lasco whirlpool spa SG72ACSK that is new and never used. I would like to add a heater to this unit, is it possible to do so? How?
It is always possible to add a heater to any jetted bathtub at any time.
What you need to find out that is if the tub is plumbed to each jet with rigid PVC pipe or flexible PVC pipe.
If it is plumbed in flex pipe then the Tee heater will be easier to install however if it is plumbed in rigid PVC then I would suggest a inline pressure heater that you will install in the water line any place after the discharge of the pump.
Here is a link to a installation instructions so you can see how all heaters are installed.
US Parts Center
Oct 26, 2013 | Whirlpool Lasco 7460621R Dossi-32 , White
Wiring from pump to on switch has come loose
You can look under the tub where the fitting is located and there is usually a nut holding that button in place.
Rod
U S Parts Center
888-521-6183
Mar 19, 2013 | Whirlpool Lasco 7460621R Dossi-32 , White
I need new jets for my lasco whirlpool aries lll where can i get them
p, li { white-space: pre-wrap; }
Click on the link below and then under the Product Options use the drop down menu to choose the color of the item you need. You must match up the jets you have in your tub to what is shown online.
http://www.uspartscenter.com/index.asp?PageAction=VIEWCATS&Category=387
Feb 20, 2011 | Whirlpool Lasco Builders Choice Ariel III...
My Lasco whirlpools tub is getting power and the air switch is working. When i fill the tub and turn it on i hear a buzzing sound from the motor but it does not pump the water. I thought maybe the pump is...
The first step is to gain access to the pump, bring a flashlight and see if the pump motor is moving by looking for some rotating part.
At the same time, ensure that it is the motor that is buzzing.
Post again with this information.
Gary
Feb 11, 2011 | Home
My lasco whirlpool tub leaks scum from the jets do they make covers to completely seal off the jets?
Oct 31, 2009 | Whirlpool Home
How to get jet covers on my lasco tub white they turned yellow
lasco jets usually unthread counter clockwise out of the wall fittings
Oct 16, 2009 | Whirlpool Lasco Builders Choice Ariel III...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Home Logo
174 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
